complete clutch line schematic
Does anyone have a schematic of the entire clutch line assembly, from the master cylinder to the slave?
I want to know the bolt sizes and thread types of the connections of each union of hose.
Essentially, I want to make a hard line from where the steel line ends to the slave cylinder, so the connection at the slave (to me) is the most important.
I have acces to flexible tubing that can withstand 5000psi.
thanks
thanks
I don't see why you wouldn't just use a brake line with a fitting that threads into the master cylinder, runs toward the slave, and complete the line with a flexible stainless steel brake line...Very simple...My clutch line is about 2-3 feet and very direct. Master to slave.
Originally Posted by 97SEdriver
Because the stuff I have access to is free for me.....it would also be better than a SS line with a teflon interior...and cheaper (even if I did have to buy it).
Jae
Originally Posted by Vlasic
Thoes fittings can be expensive. You would save a lot of time and probably not spend too much more just buying one of these.
Originally Posted by ThurzNite
any possibility of making a group deal from master to slave cyl?
Jae
Jae
So if I get it together....yes....
Mar 12, 2020 12:06 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
