Diagram Dashboard Disassembly
Does anyone know where that diagram is that shows how to take the dashboard apart? I usually dont use it, but the last couple times I've taken my dash board apart i've snapped somethin off or ended up havin to "realign" my air vents.
Was hoping that the next time i do it i could follow the diagram to facilitate the process. Thanks.
Um I've never seen a diagram but the way i do it is to take a flathead screw driver and just pop off section by section. First the shifter trim, then the ashtray/coin thingy (to get this off there is a screw you have to take off then you can remove it by pulling it out kinda hard, then the clock and 2 vents, then remove the 4 (pretty sure only 4) screws and take out the headunit and climate control stuff. It's really straight forward either way. Why are you taking it apart?
Also just be gentle with all of the pieces because they are plastic and if you're too hard on them you can be sure you'll crack it. Also i usually remove the trims by popping them off at the corners, that's pretty much the easiest way.
James92SE
142
Jan 2, 2024 09:23 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
