first time at the track... good runs??
hey guys i recently bought a 2001 SE 5 speed.... the only thing it has is a brop in k&n and a B&M short throw shifter.. they were on the car when i bought it.... i left the spare tire and jack in there....... my first run was: 8:33 73 degrees
R/T........ .167
60'......... 2.386
330........ 6.637
1/8........ 10.104
MPH....... 70.56
1000...... 13.097
1/4........ 15.639
MPH....... 88.96
my second run: 9:56 P.M. 70 degrees
R/T........ .365
60'......... 2.411
330........ 6.621
1/8........ 10.081
MPH....... 70.52
1000...... 13.074
1/4........ 15.613
MPH....... 89.05
the car has 77k miles on it and i think the origional clutch...... i just would like to know if i did ok, i thought these cars ran high 14's to low 15's..... but remember i have cali spec also.....
R/T........ .167
60'......... 2.386
330........ 6.637
1/8........ 10.104
MPH....... 70.56
1000...... 13.097
1/4........ 15.639
MPH....... 88.96
R/T........ .365
60'......... 2.411
330........ 6.621
1/8........ 10.081
MPH....... 70.52
1000...... 13.074
1/4........ 15.613
MPH....... 89.05
i cant say im up on the 5th Gen 00-01 stock times, but you could try looking in the timeslips database and see what you can come up with to compare times.
since its a new car, maybe check the ks, and check to see if your running correct spark plugs, of course run 93 octane. Then there is the VIAS check to make sure its activating.
Other than that with a bit more practice you might could lower the 60 foot a bit but still probably not looking at a 14.9x
do you have stock wheels or something aftermarket and larger ?
nice runs though !
nice runs though !
I got 2.440 60' in my 01 auto. They seem ok to me. well the rest is as follows
.2702 reaction
2.4408 60'
9.72 et @ 594ft
10.37 1/8mile et
69.24 1/8 mile mph
15.99 1/4mile mph
87.07 1/4 mile mph
I still had spare tire and some other stuff in the trunk, next week i wan going to clean every thing out and shoot for 15.8 or so. Wish me luck guys.
.2702 reaction
2.4408 60'
9.72 et @ 594ft
10.37 1/8mile et
69.24 1/8 mile mph
15.99 1/4mile mph
87.07 1/4 mile mph
work on your 60ft. 2.4 is not good by any means. If you can get it down to the 2.2 range you should be much closer to low 15's. perhaps 15.2.
Also check to make sure your VIAS is working, your traps seem low. use the search function at the top and check the FAQ it shows how to check VIAS operation.
You should be trapping at least 90 mph, no matter what your 60' is. Check your power valve. Chances are its not functioning. When I ran my dads 96 auto years back it went 15.7@87 basically stock.
lol theres no way in hell a basically stock 5th gen 5spd is gunna trap even close to 98-99mph. hes gunna need all the bolt ons to start trapping 99, because trapping 99 for maximas seems to be knockin on the doors of low 14's. seems maximas trap low compared to other cars out there.
.2702 reaction
2.4408 60'
9.72 et @ 594ft
10.37 1/8mile et
69.24 1/8 mile mph
15.99 1/4mile mph
87.07 1/4 mile mph
.2702 reaction
2.4408 60'
9.72 et @ 594ft
10.37 1/8mile et
69.24 1/8 mile mph
15.99 1/4mile mph
87.07 1/4 mile mph
to the OP: your 60's are also pretty high, with a low trap. tho 60' isnt terrible though and you can probly get it down without too much work. as for the trap, check your motor to make sure it is perfect since you ought to be trapping 90's, maybe 93.
this is actually the first time i launched the car hard...... the first time i launched at 2000 RPM... the second i did it at 4000 but then i just mashed the pedal down and spun all through first..... but it just kept pulling while spinning.... i might go in another week and try again....
Originally Posted by DasYears
yeah with a good driver. even a stock civic can pull 2.2 60's with a good driver. i was thinking 2.29's but thats still a 2.2x
Originally Posted by NmexMAX
You have little to no experience with VQ30DE/DEK 4AT's.
Unless you have experience with a particular vehicle/setup you should be a little more selective with what you post. My best 60' foot time with my stock '99 auto was a 2.3. 2.2 60' in a basically stock '01 auto (which is about 100+ pounds heavier at least) is IMPOSSIBLE with no weight reduction. Good 60' times aren't just about traction, they're also about torque. A stock auto 3.0 just doesn't have enough of the latter for sub 2.3 60'.
This is all
anyway. The OP has a 5MT.
I would say low 15,s for a good driver with that car. The trap seems to be off! But by no means will he trap 98-99 with a stock car or with them mods. Work on your 60ft and check your vias. If that pans out and dont think your clutch is sliping check compression and knock sensor.
I trapped 100-101 with my N/A dek power 4th gen. But that was with a lighter car ,full exhaust,pulley,intake,spec stage 3 clutch, ypipe,eu with advanced timing and good 13.5 airfuel. witch put me in the high 13's low 14's
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
