clarion wiring diagram- Active
Hi,
Can't seem to find a wiring diagram for the Clarion (Active) system. Could someone please post a link to either a diagram or instructions?
I'm replacing the stereo (HU) and believe I am supposed to bypass the amp in the back completely... and that the front speakers have no amp and are powered by the OEM stereo, so I can wire them directly? Is this correct guys?
(Wow- can't wait to actually play CDs!)
Thanks!
Thanks!
No need to bypass the rear amp,you can wire it into your aftermarket HU..
Click--> http://forums.maxima.org/showthread....ht=clarion+amp
Thanks but I don't quite understand this key statement on the link you provided..
"You need to hook up the rear speaker amp to a switched source..IIRC it's the blue amp wire if you used the Scosche adapter harness." Is it saying to just hook up the rear spkr amp to the blue wire and all will be ok?
Is there a downside to bypassing the rear amp?
Yiikes! I'm sorry... this should have been under "audio and electronics". Still... all replies are appreciated!
I am not sure how the rear speakers sound without the rear amp,maybe someone else can relay this info to you.
I bypassed mine. Finally got balanced sound after being overpowered by the rear speakers for years because the Best Buy installers hooked up my aftermarket HU to the rear amps.
Needless to say, my recommendation is to bypass them.
http://forums.maxima.org/showthread.php?t=430333
Post #5
Post #5
yes .. well via the new harness adaptor that connects to the hu and plugs into the wires from the dash. I guess ground is ground (black in this case?).. and should all end up connected to the chassis?
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
