3rd gen runs, shifts, won't move.
Old Jul 22, 2007 | 06:29 AM
colinod's Avatar
Starts up, runs perfectly, I can hear it clunk into gear RND21, all of them. But when I release the brake, the car doesn't move. Sometimes it does lurch forward a few inches, but it stops.
Old Jul 22, 2007 | 06:56 AM
internetautomar's Avatar
mod or sell?
Double A em see o ....
Old Jul 22, 2007 | 02:38 PM
colinod's Avatar
Would you have any idea what's wrong though?
Old Jul 22, 2007 | 03:35 PM
Greeny's Avatar
¯\(°_o)/¯
AAMCO ....
How about actually helping the guy out instead of posting word puzzles..
colinod,your transmission has failed,you will need to have it rebuilt/replaced or swap a manual transmission in place of the automatic.
All options are expensive.
Old Jul 22, 2007 | 03:58 PM
Tampamaximus's Avatar
I would check transmission fluid levels first
Old Jul 22, 2007 | 05:43 PM
colinod's Avatar
Thanks.....
Old Jul 22, 2007 | 05:47 PM
colinod's Avatar
P.S. The ATF level is good and the fluid is clean.
Can you suggest something that will cost less?
Old Jul 22, 2007 | 05:56 PM
mooze's Avatar
a geo metro
Old Jul 22, 2007 | 07:05 PM
mod or sell?
You are all assuming the worst with the trans.
it could be something as simple as an F-ed up converter.
or some thing as bad as trashed sun gears.
you don't know, and he won't know until it is PHYSICALLY inspected.
which means pulling it from the car in most cases.
Heck I've had one car that did something similar to me and all it turned out to be was that the converter to flexplate bolts came out!
$4 worth of bolts and we trashed the car out because we ASSumed it was a bad trans.
Old Jul 22, 2007 | 09:09 PM
Alex_V
Sounds like a TC to me too. Thats how I got my maxima for $300. Same symptoms. Starts/runs doesn't move. Swapped to a manual and drove.
I could have just put in a TC from my parts car but I was afraid it would fail later any way, and of any metal that got into the tranny from the TC failing. But the cheapest way to fix it would probably just be a TC away.
~Alex
Old Jul 23, 2007 | 12:28 AM
writes1's Avatar
I'm having problems with my tranny too.
My 93 GXE starts and runs fine. When I shift into D, the car won't move. Only when I shift to 2 the car moves. Then, I shift back into D and everything is fine.
Ideas?
Old Jul 23, 2007 | 05:54 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
Ideas?
i'd bet on the shifter bushing for that.. the shifter is not firmly connected to the shift cable, so there is some freeplay, so you'd hyave to shift a little deeper (into 2nd) before the cable-end was fully in D, then when you shift back to D the cable stays put.
http://s164.photobucket.com/albums/u...t=MVI_2278.flv
that's what my shifter looked like w/o the bushing. $2.53 from my local dealer...
test it by shifting into L, and see if it shifts as though it's in 2. or leave it in 2 like you do, and see if it shifts as thought it's in D.
Old Jul 23, 2007 | 02:19 PM
MaximaN00b's Avatar
Originally Posted by mooze
a geo metro
LMAO that really had me laughin out loud
Old Jul 24, 2007 | 11:19 AM
colinod's Avatar
Well started her up this morning, and now it decides it wants to go forward flawlessly and not reverse. So the tranny shop man came over, put up the car on a jack, wheeled it around and drove it off. No, the car wouldn't go into neutral.. if you'd think that would be a less extreme approch to get the car outta the lot.
Old Jul 25, 2007 | 06:45 PM
bhunter's Avatar
You hadn't put a new axle in it had you? I got the wrong axle one time and the car wouldn't move. Got the right one in and all was fine. Visually inspecting the axles there was very little difference.
Old Jul 31, 2007 | 10:05 PM
writes1's Avatar
capedcadaver
So this is what is now happening: I shift into D and deeper into 2nd to engage the gear. Then, I shift back in D to go.
Today, I shifted down through the gears and the same is occurring in all the gears. However, when I go back up through the gears the shift just fine.
Sound like the bushing still? Is this something a novice mechanic can do himself?
Old Aug 1, 2007 | 07:18 PM
Alex_V
Theres been a few topics on it the last few days. Within a few topics of this one. If you can't find it use the search function.
~Alex
stevesmax
Dec 17, 2020 11:57 AM
alixc
Aug 11, 2020 01:48 PM
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
