Nismo Short Shifter
Here's a nice little writeup in the FAQs that tells a little about it:
http://www.vbxmaxima.8m.com/shifter.html
assuming that the NISMO shifter is the same thing as the Courtesy Nissan, which is what I would guess.
Got one in my car. make sure you get your own bolt b4 hand. I'm a machinist so i took it to work and had the welder check the welds -- Loved them, then i took it to the inspector and he ran a few tests (lpi and ultrasound) on it and they passed, then i put it in a hydraulic press, held all the way to 300psi (didn't go further so as to not break it). #00psi is more preasure than we will put on it even if you are slam shifting it. Love it.
i got the shifter n bought it wit the nismo CF shift **** and apparently it dnt fit so yea.. i now have da shift **** on da shifter but i can take it out weneva.. n dnt have any idea on how to make it stay on.. so if u gettin this shifter dnt get it with the nismo shift **** unless u have some way of makin it stay on.. if so let me kno how u did it
by the way the only real short throw shifter available at least for the 4th gen maximas is B&M shifter the others are just shorter lenght sticks read more about this here
http://forums.maxima.org/showthread.php?t=219944
http://forums.maxima.org/showthread.php?t=255634
by the way i wrote this several times no matter how much you cut down the stick it will not shorter the thorw of the shift what the sts do is shortens the distance between each shift instead of traveling like 3" or so from 1st to 2nd and so on it only takes like 1 1/4" or something like that
one more thing nismo don't make any short throw shifter for the max
Originally Posted by mtrai760
Wow, there have been several dozen post about these, but you had to start your very own thread about it. Thanks.
anyways i know its kind of a janky makeshift way to get a shorter shifter is to cut it an inch or two thats what i did, but basically the only thing in a short throw is that the pivit ball is moved higher towards your hand (obviously you knew that) anyways i would save some extra cash and just cut it your self. thats what ive heard alot of people do on the org.
im just sayin.
Just an FYI to all you ohmygoditsnismojdmkewl dinkers... Nismo make ZERO parts for the maxima... these are all cheap knockoffs of the pacesetter short throw, which was not that great to begin with, then make a knockoff of it...
You get what you pay for.
jmlee44
Oct 2, 2022 02:13 PM
05RLS2
Apr 14, 2016 11:49 AM
atriuum
Sep 28, 2015 01:19 PM
