Need help on rear end sagging!
I have an 97 SE and have about 250lbs of audio stuff in my trunk. my car sags and i hate the way it looks.(usually will sag alittle with a full tank of fuel w/ no system)any way the list will grow and it will be about 350lbs so what are my options. I was think new SE struts in the rear and maxspeed in the front..maybe to even it out..or i could do ground controls all around with new struts (SE). Another thing is its bounces every where when someone sits in the back seat...im open to anything thats affordable my main interest is SPL..Also i like the look of it beening lower 1.5" max tho...
-Thanks
-Thanks
If you use any type of lowering springs it will definitely help. The springs will be much stiffer and will not...or at least should not sag much if at all. Most springs will lower your ride and make it just about even all around. I would not suggest just installing springs ONLY up front to even it out.
Sounds like your struts are already blown...with the mention of the bouncing.
hmm new struts and maxspeed ALL around
I just hope it will handle it
Linear springs?
And this may sound dumb but what are the difference between shock and strut? shocks are up front and struts are in the rear?
I just hope it will handle itLinear springs?
Originally Posted by JEXTEL
Coilovers cause i can adj. the front to how much the rear is sagging? and will they work on fresh SE struts and shocks?
These will not work with stock struts...
doctorpullit
Sep 10, 2015 06:33 PM
