Power Steering leak: advice from old people
Old Aug 27, 2007 | 04:47 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
Well my grandpa and his neighbor are ALWAYS hassling me about being the Maximaniac that I am. They keep telling me to junk it, or that every time I touch it, I should make sure i have enough money for the mod/part/whatever i'm buying, as well as a replacement car when I fukc it all up.
Well, my power steering leaks at the connector where the PS pressure sensor is located. I wanted to use an air wrench to pull the bolt out, and look at what is going on in there. Now, the rubber grommet attachment makes it hard to do that without manually holding the rubber-sleeved end of the hose to keep it in place while loosening that bolt. Unfortunately, the FSM is no help here. Well they are asking me all kinds of questions about what it goes to and what metals different components are made of and all kinds of stuff, then saying "well just caulk it and be done with it".
So the question is.. is there any form of caulk or anything remotely similar that can be applied around the leaky connector that can resist both temperature and the caustic nature of PS fluid? And is that metal section before it turns into a rubber hose strong enough to hold onto while unbolting that connector such that it won't snap off when impacting it?
Old Aug 27, 2007 | 06:49 PM
maxitech's Avatar
Not sure, but are you using P/S fluid, or A/T fluid as recommended by Nissan?
Old Aug 28, 2007 | 01:14 AM
a blend. as it leaks out, it's slowly being replaced by Dextron III.
Old Aug 28, 2007 | 06:00 AM
Greeny's Avatar
¯\(°_o)/¯
Where is it leaking exactly,at the pressure sensor,or at the top bolt?
If the leak is around the banjo bolt fitting,then you will need to replace the copper crush washers with new washers,i am not sure where to get these washers,but the dealership may be your best option to find the correct parts.
Anyhoo,the best way i have found to remove the large banjo bolt safely is to remove the rubber grommets/replace them with washers or nuts like in the pics.This eliminates movement of the whole piece(note:you must remove the metal sleeve from the center of the rubber grommet before they will slide out of the side of the p/s hose bracket)
Do not use an impact wrench on this bolt unless you want to break the bracket/housing..You need to use a large close end wrench like pictured(note: the bolt is 24mm,but a 15/16 wrench will work without stripping the banjo bolt),put consistant pressure on the wrench by leaning into it with your body weight until the bolt breaks free.
(Disclaimer: I am not responsible for damages if you break something)
I have not yet broken a bracket/housing using the method detailed above.
Old Aug 28, 2007 | 07:26 AM
Mr.Davon24's Avatar
For the bottom part of the hose (connection) is the same size bolt?
Old Aug 28, 2007 | 08:08 AM
Greeny's Avatar
¯\(°_o)/¯
Yes,the bolts are the same size,top and bottom.
Old Aug 28, 2007 | 11:05 AM
Mr.Davon24's Avatar
thanks again that damn bolt was given me so much problems I am going to try the other method. Kudos
Old Aug 29, 2007 | 04:01 AM
wayne you rock. I had a hard time getting both bolts to hold that bracket in place so i had to loosen it with just the driver-side one in place, and i hope i got the big bolt tight enough after putting the new crush washers on. $7 from the dealership. And the new ones were 3x as thick.
as far as i can tell, no leaking so far. I held it at lock for both sides for about 3-5 seconds each side, and it's still dry. Thank you so much; this problem has been plaguing me for months. Now i can FINALLY get new bushings.
though sadly there is a chance that my time with teh Maxima is limited. I may sell it to my cousin since she really wants to ditch her car and will need a replacement, cuz her brother has 2 cars and one for sale, but she doesn't want another 5spd. So I may end up with his 94 Altima GXE (KA24DE) 5spd instead. but at least the maxima would stay in the family.
Old Sep 4, 2007 | 02:48 PM
iciqueen's Avatar
ok...i have to replace my power steering hose tonight...is there any special instructions etc....have a friend helping me, but he knows nothing about these things..i have a 91 Brougham, which i assume is the same as a GXE the new hose came with a little yellow plug and some metal washers...geez do i ever sound like a female.. anyway if anyone has some advise would be helpfull!!!!
Old Sep 4, 2007 | 03:10 PM
Greeny's Avatar
¯\(°_o)/¯
The little yellow plugs should have been in each end of the hose to prevent dirt/trash intrusion,just discard them. The washers go on each side of the round ends of the hose,these washer seal the connections when they are tightened down.
What kind of tools do you have to work with?(i.e. Do you have jack/jackstands?/24mm or 15/16 close end wrench?/10mm socket or wrench?)
The hardest part of the hose replacement is lack of room to access the bottom banjo bolt on the p/s pump side of the hose,this is the only reason i purchased the long close end wrench i pictured above,i guess what i am trying to say is the right tools are key in this project
You also may have to bleed the power steering system of air pockets after the hose install..
Bleeding procedure:
1. Raise front of vehicle until wheels are clear of the ground
2. add fluid into tank to specified level, turn steering wheel quickly from left to right,lightly touching the steering stoppers..repeat procedure until fluid level stops going down.
3. Start engine, then repeat step 2 with the engine running.
Old Sep 4, 2007 | 06:15 PM
UPDATE: 1 week later and i'm still dry. thank God it's over! i guess the washers had flattened out too much, and when the banjo bolt bottomed out, there was still some extra room that should have been taken up by the washers, because the new ones were about 3x thicker. So now that they are covering that extra clearance, the leak is gone.
Old Sep 4, 2007 | 06:37 PM
iciqueen's Avatar
Yes i have all the proper tools, as i took the hose off my parts car..much to my dismay, it was the wrong hose...so i had to get one in today...i just wanted to make sure i know what im up against,....thanks....i will let you know when the job is done!!
Old Sep 4, 2007 | 07:30 PM
ustfdes's Avatar
- Product of Maxima.org -
wayne, do you have all these photos on file, or do you go take them immediately to show a fellow .orger?
you always have pics to illustrate....it's awesome.
Old Sep 4, 2007 | 07:36 PM
Yeah he's quite the prophet. I've been wanting to fix that leak of mine for, oh, 6 or more months. i need to remove some fluid now, since i overfilled it anticipating further leaking. But it ain't leakin' no mo!
I mean, i often take pictures on the spot, leaving the keyboard in mid-post to see what i can capture on film, er, SD card.
Old Sep 4, 2007 | 07:50 PM
ustfdes's Avatar
me too, but not as often as most. ...if i think it will help, i don't mind doing it. ;x
Old Sep 4, 2007 | 09:02 PM
Greeny's Avatar
¯\(°_o)/¯
Kinda half-n-half on the pics,some i take when the question comes up,some are already on file. I always liked the books in school with a bunch of pictures..
Seriously,any solution to any problem on a car can explained with text,but i always have found that "a picture is worth a thousand words"
Old Sep 5, 2007 | 01:08 PM
iciqueen's Avatar
Well...thanks for the help!! Power steering is done...on to the next project..exhaust~~
Thanks Guys
Old Sep 5, 2007 | 07:07 PM
Thanks Guys
yep same here. well mounts then exhaust.
Old Sep 6, 2007 | 08:57 AM
Mr.Davon24's Avatar
I can't get this friggin banjo bolt off its leaking right at the hose ends. I think I already put enough fluid in there to fill a bath tub Is this one of the trick builts where you have to go counter clockwise?
*edit*
maybe its the damn socket.
Old Sep 6, 2007 | 10:34 AM
Greeny's Avatar
¯\(°_o)/¯
*edit*
Huh?
You normally go counter clockwise to loosen most bolts=You need to be pushing the wrench/rachet toward the engine if your wrench/rachet is clocked in the same position as my wrench picture above..
Old Sep 6, 2007 | 11:29 AM
Mr.Davon24's Avatar
Originally Posted by MyGreenMax94
Huh?
LOL I ment to edit that lol Thanx green max... I had a retarded bolt on my honda ( I know diffrent car) but, I've had the thought since its so hard to come off. that went clock wise. So to set things straight I need to be pushing top banjo counter clockwise? They should have some type of props /kudos button to press. You're always helping me with my dumba55 questions lol.
Old Sep 6, 2007 | 01:59 PM
*edit*
http://forums.maxima.org/showpost.ph...45&postcount=4
pay attention to the bracket. he removed the rubber and bolted it straight onto the other bracket. that way it provides a more stable way to put force on it. And trust me it takes a little bit. get the new washers first! that's really important. $7 at my local dealer.
Old Sep 6, 2007 | 06:27 PM
Mr.Davon24's Avatar
thanks cap I took the gromets off already I just needed to know the proper direction. I'mma take a crakk at again this weekend.....
Old Jun 17, 2009 | 08:40 PM
maxinout93's Avatar
Im glad someone said something about power steering. It is one of the jobs ive been avoiding for a while, but just cant anymore. My Power steering fluid is leaking all over my control arm to the point that it has ate up the new bushings on the arm, which is very annoying to hear that noise as if something is loose under the car. I will soon find that leak and fix it. It is one of the things at the top of the to do list.
Old Jun 18, 2009 | 11:28 PM
Garf's Avatar
dude... blue bar @ the top of everyone's post shows the date that they made that post... last one on here is 2007. now you know.
Old Jun 19, 2009 | 01:54 AM
DennisMik's Avatar
yeah, but at least he is doing research.
Old Jun 25, 2009 | 03:52 AM
maxinout93's Avatar
Thank you!
Old Mar 30, 2011 | 11:03 PM
GalvestonGal's Avatar
I have read all around this forum til my eyes are bleeding and I give up. ALL I WANT TO KNOW IS THIS: does a high pressure,from the pump, Gates power sterring hose have to be bled after installation? Mine sprung a massive leak up by the strut and was spewing ATF everywhere for about four days - that's how long it took to get the dang hose delivered to Galveston Island. Had it installed by a local mechanic. NOW ... at every turn,the steering wheel is harder to turn than ever! It didnt even do THIS when I was pouring quarts of ATF in it to keep it going til the hose arrived! The guy who put the hose in said it was because I "waited too late" and now the "valves in the power steering pump are shot." Sounds like blarney to me, ie .. 'gimme more money to fix what I should've fixed in the first place.' Whatcha think?
Some other mechanic said it was cause there was air in the line. I dunno! The pump isn't making any noise; there isn't any leak. Any ideas, folks? I'm stumped. AND I have NO Idea if this question is even gonna post ... something about me needing to make 15 posts before I can ask a question?! For real? I dont have 15 questions!
Got this 1989 Nissan Maxima GXE from an old man, who put 168k miles on it. The CarFax listed NOTHING mechanically wrong. Replaced two front tires, the moon roof is sealed shut cause it leaked and the carpet on the passenger side is gone DUE to that leak. It runs like a top otherwise - fabulous gas mileage, low insurance rates, and it only has a couple of lil dingies here and there which I plan on fixing. Otherwise, new struts are definitely needed - we bottou out leaving every parking lot! The front air dam is held on with bread ties (the kind the cops use to handcuff people nowadays lol) .... LOVE the car though. Drives straight and clean. Cream colored with brown interior.
Am near Houston and Pasadena, Texas if anyone knows a GOOD Nissan guy/gal there. Ready to fix up this baby for my 21 year old son's college grad gift! Shhh! :-)
Old Apr 1, 2011 | 08:54 AM
Augustus Maximus's Avatar
I don't know what you were searching for but, in my search it is beyond clear to me that (1) the system should be bled (2) it is self bleeding and (3) this is done by lifting both wheels off the ground and rotating the steering full left and right a couple times, then let the car down till the wheels are just touching the ground, start her up then continue bleeding. If it's still hard after that you have my permission to look into a PS pump .
lowpost99
Oct 26, 2025 06:53 PM
2kmaximel
Sep 10, 2015 08:13 AM
trungg86
Sep 4, 2015 04:58 AM
Johnny9595
Sep 3, 2015 05:18 AM
