Clear Corners.. easy to STEAL
Originally posted by Sexima
Thanks a bunch
but i don't really understand this thing..
pawl? what is a pawl?
Thanks a bunch
Put a deep socket on it and turn counterclocwise to remove.
to secure the lights in remove the 10mm hex on the back. Install the light and reaching from underneath the bumper
to thread the screw back into the light. You will need to remove the plastic plug and install a large flat rubber washer between the hex screw and the light. To get behind the clear corner you have to pull back the wheel fender liner. There are two screws under the bumper behind the fog light holding the liner in place.. Take the liner and pull it back enough to get your hand and wrench in so you can tighten the 10mm hex back into the clear corner.
Or if you see them you could open a cap of WoOp *** on them... If your that worried about your clear corners, then weld it on or something... what happens when your get rims...? exause...? intake...? supercharger...? if someone wants it that bad then that will figure out a way to take it...
Yeah, what the f**k! I had mine stolen about 5 months back, never bothered to replace them (Man, the stock ambers just makes me wanna vommit). Good thing they were the old euro clears. I wanted to switch to diamond cuts anyhow. Not so much the money but a big pain in the @ss since I live in canada and can't visit a shop to pickup new ones. Few weeks ago, someone also made off with my covers for my sidemarkers. I installed those sidemarkers like years back and I can't even find replacements that will fit the drilled holes on my fender. Gotta see these things, they're huge, slightly smaller then a business card. It's pretty dumb that you can't buy just replacement covers for aftermerket sidemarkers but only the whole assembly. I've check with most manufactures and can't seem to track these down. I've tried APC and Eurolite but they're too small. If anyone knows of other aftermarket sidemarker manufactures, lemme know.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
j/k
