DBM or anyone else.. follow up question to yesturdays post regarding EVAP system...
I've just noticed that I don't have pressure in my fuel tank. I am not sure if it's supposed to do that, but when I open up the gas cap after driving, there is no air suction noise at all. My other maxima had that noise.
I understand the 0309 code is regarding the EVAP Canister Vent Control Valve. If this valve is stuck open (just what the trouble code states) can this be a cause for the lack of pressure? I'm going to inspect my gas cap now as well, although I am not sure how I can check it's function, maybe blow on it and see if there is a vacuum?
thanks
thanks
thanks
thanks
thanks
thanks
Originally posted by AndyXXL
Wait, so did you actually get the "check engine" light and pull the code, or did you just assume it could be EVAP CVCV malfunction?
Yep, got the service engine soon light and pulled a couple of codes both related to the EVAP system.
Daniel, thanks. I'm going to look at it this saturday.
Hi, I'm a newbie, so be nice.
Some basic questions, since I was just told by the dealer that I got codes relating to the evap/separator system as well:
1. IIRC, the '96 Maxima's were NOT OBDII, correct? If so, is there a cheap way of retrieving codes, or do I have to go to the dealer?
2. Are the codes "self-clearing"? I.e., if the problem is fixed, does the code go away, or does this also require a trip to the dealer to get the flag cleared? An ECU reset didn't seem to make it go away, even momentarily (it was back immediately).
3. What ill effects are present if the evap system fails? I was under the impression that it was primarily an emissions issue, and therefore could wait until I could find time to crawl under the car. I mean, I'm all for green and all, but I just want to make sure the car doesn't burst into flames if this isn't taken care of right away.
Thanks.
Thanks.
Thanks, Daniel!
I'm still finding my way around the site, so I appreciate the pointers to the stickys.
I could've sworn my car wasn't OBDII. Oh, well. That's $75 blown at the dealer, when I could've just used my friend's OBDII scanner. Stupid.
Again, thanks for the info.
max_speed97
Aug 26, 2015 07:46 PM
doobadoo
Aug 15, 2015 06:43 PM
