2K2 lights Pictures installed!
First of all let me say to all of you that doubt my A$$, The hell with you all of you. Every god damn one of you.
All yall do is bit#h because you aint see no pictures.
Cant even give me some time to put up the pics.
Here is the link of them installed.
http://www.geocities.com/dsuthar/2k2lights/
The pic labels lightmodification.jpg, shows where that I had bang with the hammer the body of the car to make the light fit, also had to remmove that white clip on the bottom to make it fit also.
Anyone else wanna flame because they never believed me can flame on, why not come to DC so you can bring it to my face.
Dixit
Dixit
Originally posted by BigDogJonx
Cause i aint no Bit#h A$$ admin that deletes posts and tries to make it seem like i was BS'ing.
Bring it here to DC fool.
Do that and come back here so we can have a discussion.
Re: .
Originally posted by Y2KevSE
So you think I deleted you post? Why don't you check the "Redline ATF" post and see where the thread starter's post is?
But still, aint no reason for peoples to flame. NONE!
Yeah well aint my fault the damn server so freagin slow and cant put up my post. I am on a freagin T1 and the joint is ultra slow.
So... who's this "Bit#h A$$ admin" you're talking about?
Re: ..
Well, it isn't their fault either because the server didn't come through with the post. We are all experiencing the same problems as you are so there's no need to get so hostile because of crap like that.
Plus there is still a problem because you cant flicker highbeams because the relay turns off the HIDS everytime you turn on the highbeams. I will have to invent a wiring relay for that.
But still dont know if it was worth all of this crap.
Dixit
Dixit
Dixit
You sound mad
wanta cookie?
Listen its all good, I call truce if you do. Lets just say that I got the joint installed, but it aint a easy install.
Dixit
Dixit
Good luck with the high beams.
Originally posted by mdeal
How did you wire it? Did David B provide some connectors and you rig it up?
Dixit
Reach out and touch, somebody's hand, make this world a better place, if you can! Can't we all get along? There should be no anna on the board. So Kev and Big dog I want you guys to put your arm around each others shoulders and repeat after me," You have friend in me!" Now is that better?
Originally posted by Chuvak
WOW! Great job man!! Looks amazing!
So how much will the entire thing end up costing, including every last detail?
Still looks like more than 5-min. or was that 15-min, hmmmmn.
Dixit
Dixit
"American parts, Russian parts, ALL MADE in TAIWAN!!"
Anyways, thanks for the heads up.
Like $435. Because it was extra for the plug and connectors.
Gotta check your sig now! U gotta wash your car btw
Are the plugs the $29/side units from Dave B?
If so ... what are these connectors u r talking about? What do they cost .. where can we get? I'm totally illiterate when it comes to electric wiring etc ... so n e additional info would be great!
Tkx!
Originally posted by ohboiya
Hey Bud,
Tkx!
Hey Bud,
Tkx!
Originally posted by serin
this post went from a being unnerving to mean to funny and now back to a little unnerving again.
this post is rated R...
hahhaha sorry i couldnt help myself...
i c s/o found my off-topic source ... or am i being presumptuous?
Originally posted by ToYLeT902
i'll try and make it very unnerving
All of the sudden this thread went from
to
. Big Dog and Ice I think you two are the only ones to try this (i think there is one other)and all I got to say is thanks for being the "ginea pigs," (for lack of a better word) pioneers if you will, on this 2k2 headlight install. Your efforts are very much appreciated, not only by me but as well as others (i'm sure) who are waiting to see if they should get their 2k2 headlights. Good job on the install.
to
to
to
Wow...looks better in the shots than in person. I saw those on a 2002 near my house, but the round lights just didn't seem right. But on the black car, kinda looks sporty. I wonder how good on a white 2000?
Btw, my local dealer can get me the 2002 rear (which I think would match my white car better than the red ones I have) for $175 each. Does that sound about right? If I don't wanna screw it up, how much you think a job like that would cost for them to do?
Dixit
To fix the HID problem when you put on the high beams would a relay (power on high beam side ground path, relay switch in parallel with the low beam ground side) work? This way, when thw high beam is energized, the relay would close and provide a ground path for the HIDs as well, keeping them lit.
i thought Dave was selling his for a little over $200 for the pair?
don't quote me but do your own research ...
Folllow up on HID relay
Looking a little closer, the relay should be as follows:
Currently, headlight terminal #1 is highbeam ground and goes to terminal #6 on light switch. Terminal #2 is lowbeam ground and goes to terminal #7 on light switch.
With HID's:
Highbeam ground to terminal #1 of Nissan relay (normal open) and #2 of relay to terminal #6 on light switch. HID ground directly to terminal #7 on light switch. Also, from HID ground to terminal #5 of relay. Terminal #3 of relay to terminal #6 on light switch.
When HIDs on, relay is open.
With highbeam on, relay closes and ground for HID connected, allowing HIDs to remain on.
Need to check to be sure current flow with bot HIDs and highbeam are within limits of light swirch.
With HID's:
Re: Folllow up on HID relay
With HID's:
With HID's:
Dixit
i'ma get me one right now.. i hope the guy will hang onto those beforei get back.. i'm affraid that the pricing is wrong and they'll fix it soon. so i'ma get me a pair of them lights right now..sounds too good to be tru
