At what drop do you need camber plates?
Old Sep 3, 2001 | 10:19 PM
theMax's Avatar
Thinking about sprints but with a 1.7" drop, are camber plates needed?
Old Sep 4, 2001 | 01:27 AM
my01SE
I have that same question, I just purchased Eibach springs, ( 1.0 drop in rear, and 1.3 in front) will I need camber plates when I put the springs on? Please let me know!!!!!! Thanks!!!!!!
Old Sep 4, 2001 | 05:34 AM
UMD_MaxSE's Avatar
Got Bent?
with a drop of around 1.5" you are probably ok without camber plates. As you go to 2" though, you should get them or your wheels will look like this:
Old Sep 4, 2001 | 07:03 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Nope, you don't need them with those drops.
Old Sep 4, 2001 | 09:11 AM
gramenis's Avatar
Quick question:
I just lowered my maxima with the Eibach Pro-kit/Tokico Struts setup; how important is an alignment?
Thanks.
Old Sep 4, 2001 | 09:27 AM
Y2KevSE's Avatar
Originally posted by gramenis
Quick question:
Thanks.
You should have it checked/fixed whenever you get a chance.
Do what I suggest, but don't follow what I do because I still haven't gotten an alignment yet.
Old Sep 4, 2001 | 10:32 AM
UMD_MaxSE's Avatar
Got Bent?
not even after dropping it with GC's?
Old Sep 4, 2001 | 11:15 AM
Y2KevSE's Avatar
Hehehehehehe...............
Old Oct 9, 2001 | 11:54 AM
dashingMax's Avatar
Hmm... So you guys are saying that after up to 2" drop one does NOT need a camber kit? Or is there some sarcasm going on which I fail to comprehend?
Old Oct 9, 2001 | 12:07 PM
UMD_MaxSE's Avatar
Got Bent?
if you drop it 2" or more, you should consider camber plates..... anything less than that, you will probably be fine without them
Old Oct 9, 2001 | 12:39 PM
dashingMax's Avatar
The keyword "probably" makes me uneasy. Can you install the camber kit without taking apart the strut/spring combo?
I don't want to install lowering springs, put everything back together and then re-open everything just for one stupid bolt!
What is this Camber Bolt/Kit thing? I know what it does, but what is it?
Old Oct 9, 2001 | 12:43 PM
UMD_MaxSE's Avatar
Got Bent?
well, with the drop that eibachs give you, you won't need any camber adjustment. The negative camber won't be too much....
Old Oct 9, 2001 | 12:48 PM
Jeff92se's Avatar
I'm needing a caw
There is no 100% drop rule for camber plate. You will need camber plates if after your car is lowered, it's beyond the adjustable limits for simple camber bolts. Period, end of discussion.
Old Oct 9, 2001 | 01:34 PM
BSwithTF's Avatar
I had to get camber bolts.
I have the Sprint/Tokico combo and I was getting horrible wear on the inner edge of my front tires. They put the camber bolts in and so far I haven't noticed any inner edge wear as of yet. The print-out they gave me was much better after the camber bolts were installed. Cost me $33 a side plus the cost of the alignment.
Old Oct 9, 2001 | 01:41 PM
matt calder's Avatar
no camber plates over here.......
Old Oct 10, 2001 | 01:52 PM
2kseman's Avatar
Got my Eibach springs on for about 4 months, no noticable wear on the front or rear tires...just had the alignment done...
Old Oct 11, 2001 | 11:29 AM
adman's Avatar
No camber plates! But, plenty of sarcasm!!!
Nope...you really don't need them.
Get it aligned after your done.
ADMAN
knight_yyz
Nov 1, 2015 01:34 PM
maxima-junky
Oct 7, 2015 06:13 PM
ricky7780
Sep 24, 2015 06:50 PM
