Too much coolant?
Old Sep 22, 2007 | 01:27 PM
!PrjctMax!'s Avatar
Too much coolant?
Is this possible? Why is there no "over-fill" tube that lets excess come out?
I remember checking my coolant before and it was higher than it should be and when I took off the radiator cap, it started flowing out...and right now I just checked the reservoir, and the level is about 1/4-1/2 inch higher than the word MAX. printed on the side.
STUPID question, but is this "bad?"
Old Sep 22, 2007 | 02:04 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Was the engine still hot when you removed the cap??? IMO the overflow is higher because it did boil over, the fluid came out the radiator cap because it was still hot, check the radiator and I'll bet it's low. There is no other magical place for the fluid to go (unless you have a leak), I recommend ensuring your levels are correct and watching your temp gage the next time you drive and see if your engine is running hotter than normal... (thermostat could be suspect)
Old Sep 22, 2007 | 02:08 PM
!PrjctMax!'s Avatar
ya, the engine was still hot, but the fluid was not "hot."
My temp gauge is always the same, but my main concern is if it's "bad" that there is more coolant in the reservoir than there should be?
Old Sep 22, 2007 | 02:14 PM
chernmax's Avatar
Then the thermostat may be failing IMO, but then again the car would be running hotter than normal...
Old Sep 22, 2007 | 02:39 PM
redls1's Avatar
MAXIN' ON
The only thing that will hapen is that if it really does overheat it will come out the top of your overheat bottle into your engine bay. You could always pull the hose and fill it to proper level and go from there.
Old Sep 22, 2007 | 03:16 PM
!PrjctMax!'s Avatar
Come to think of it, there was coolant crud by the actual reservoir. I think I may drain some now
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
foodmanry
Sep 24, 2015 12:02 PM
msellas
Sep 23, 2015 09:16 PM
junito1
Sep 23, 2015 12:14 PM
