Can you cheat with MAF sensor readings to run leaner?
Don't bash me if this is ridiculous, just thinking..
Is it possible to install a very light resistor on the wire that returns the MAF sensor readings to the ECU so that the ECU injects less fuel and you run a little leaner?
I'm no electrician but thought it would be nice if I could put a resistor that will shift all values with like 5 - 10%.
My car runs rich now and apparently I think too much about it now..
You must not understand. You cannot do that. no one here has any way of knowing wat resistor you should try, cuz no one here knows how rich your car is running, do you even have a wideband reading? do you know at what rpm you are running rich? if you put a resistor(if it even works), it will make it leaner at every rpm, even at rpms that need no change in air/fuel. just think about what ur trying to do, and read up on basic understanding how air fuel controllers work. you can adjust your air/fuel somewhat, by using a fuel pressure regulator, you have no control on what rpms to make it leaner, but its better than a resistor. you lower your fuel pressure so it runs leaner. done deal. afpr's cost like 50 bucks or so.
The only problem with your idea is (beyond the obvious, A/F is never a flat line across all RPMs and throttle positions so you won't have good corrections), if you miscalculate or are already somewhat line or right on stoich at one position, a leaner AFR may very well blow your motor. That's more so if you miscalculate and it get it very lean, though.
Also, do you know exactly how rich you are running? Do you have a wideband? The ECU will try (and, generally, succeed) to run right at 14.7 in closed loop, and you want to run it leaner?
If you are running 87 or 89 octane, try using 91 octane. When the KS detects pre-ignition, ECU will enrich the fuel mixture and retard timing. People reported much better mileage on the freeway with premium.
My car has never seen lower than premium gas.
What kind of lunch are you having that you can buy AFC if you skip a couple? Those SAFC2s are all over 200$. And for what? Just to adjust the AF under WOT? Although it will look cool at night under my head unit.. I have an empty space now. Are those apexi safc2 single din in size?
Sorry I guess I meant don't be a cheap *** but didn't come right out and say it. You think it makes sense to use a resister, then use it. Post up results (dyno). You could also slice up your MAF and put the element in different sized piping based on calculations.
kjlouis
Nov 24, 2018 06:09 AM
doobadoo
Aug 15, 2015 06:43 PM
