Dallas Taillight Mod
Old Oct 4, 2007 | 03:20 PM
aporozco's Avatar
Stock Airbox Supporter #3
I was planning on doing the Dallas Taillight mod this weekend. I was wondering if anyone has done this before and what your input is. Also, i was wondering about the glue that holds the lens on.
After I heat up the taillight and put the lens back on, do I need to apply more glue or whatever it is or is there enough on there. I dont want any leaks or condensation. Thanks a lot.
Old Oct 4, 2007 | 05:36 PM
RicoSuave98's Avatar
hell no you don't have to add more glue. that **** is sticky as hell son. i messed up some lucky jeans doin that. my best advice is use a heat gun and high temp paint. it's a really simple deal and makes a huge diff
i went from red/ clear
to traditional DTMs
Then I slapped some tint on em
Old Oct 4, 2007 | 05:38 PM
damn i never noticed the diff in my muffler tip. the first 2 are stock with a tip and the last one is my flowmaster.
Old Oct 4, 2007 | 05:42 PM
+1 ^^^ on the advice about glue. No additional glue is necessary.
Just follow the DTM instructions on VQpower.com and you'll be just fine.
I put them in the oven at 175 degrees for 3 minutes to seperate, then again to put back together.
Old Oct 4, 2007 | 06:43 PM
redls1's Avatar
MAXIN' ON
Emanage Ultimate
Old Oct 4, 2007 | 08:40 PM
aporozco's Avatar
i got ththis paint cause it says bonds to plastic. or should i use rim paint cause ability to withstand temp. or enamal rust protector cause vqpower.com says so?
thanx a lot....
Old Oct 5, 2007 | 08:24 AM
For DTM, the paint you bought will work just fine. Heat will be next to nothing as the turn signals are not on all the time.
Old Oct 5, 2007 | 10:17 AM
MaxBoost925's Avatar
Drug Money
Originally Posted by redls1
Emanage Ultimate
WTF does this have to do with tailights?
Old Oct 5, 2007 | 04:16 PM
redls1's Avatar
MAXIN' ON
HMM good point, I thought I saw in a post where someone was asking what eu inside in meant.Must have been a different post. Man Im slippin!!!!
Old Oct 5, 2007 | 04:26 PM
glenmoormax's Avatar
10 psi
hey ted, what did you use to tint them. I tint tail lights daily for people but i use a brand called rikochet and it's like a clear bra material. Did you use regular tint? they look clean though, i checked them out up close when you were at work and sw your car...
Old Oct 9, 2007 | 09:24 PM
aporozco's Avatar
Finiashed Product
I did these last friday. When I put the lenses back on i noticed that I could see the Bulbs in the housing. Something I did not think about. I think it wud look better with clear/rads done with this mod. I still like them though......
Here is the finished product:
Before
Old Oct 10, 2007 | 03:10 PM
VQA32SE_L's Avatar
Heres mine, I left the reverse light part clear...
Old Oct 10, 2007 | 03:12 PM
aporozco's Avatar
did u do the AE headlights urself too?
Old Oct 10, 2007 | 03:23 PM
VQA32SE_L's Avatar
Yup after doing the tailights I noticed how easy it was, so I went ahead and did my headlights too. Just follow the instructions on Vqpower.com
Quick pic of the 5th gen that i did...
Old Oct 12, 2007 | 04:23 PM
rome06's Avatar
yeah its not that hard
Old Oct 12, 2007 | 09:13 PM
seanwn's Avatar
i think i just found the first mod i wanna do to my car
Old Oct 15, 2007 | 02:47 AM
tvis's Avatar
DTM FTW
Wish I could do that with my 95/96's, but it looks like I'll hafta just settle for doing a light tint on the signal's and b/u lights.
Old Oct 16, 2007 | 12:03 PM
Much, much better aporozco.
Here's mine. A little bit different approach than most.....
Old Oct 16, 2007 | 12:24 PM
tvis's Avatar
^ The winn4r
Old Oct 16, 2007 | 12:49 PM
aventerav's Avatar
SICK max wizard
Old Oct 16, 2007 | 08:33 PM
damn i think that is the first time i've actually liked the *** end of a maxima completely shaved. well done. and about the bulbs idea i painted my signal lights black with the same paint. i had an extra pair so i didn't care if they got ruined. turned out really cool. not the best light output (go figure) but was bright enough and did the job
Old Nov 12, 2007 | 12:50 AM
idtag's Avatar
Can you do that on the 3rd gens?
Old Nov 12, 2007 | 03:29 PM
maxima1239's Avatar
When I did the tail light mod i just took the orange piece out and put it back together.
It looks like VQA32SE_L taillights (the previous reply's).
Old Dec 10, 2007 | 02:10 PM
Caracicatriz's Avatar
What was that?
IT's SUPER EASY TO DO
Old Dec 10, 2007 | 02:46 PM
2themax99's Avatar
In relation to tail light talk, I recently purchased the Ebay LED tails for the 4th gen maxima, and I need help with a wiring project. My goal is to rewire the tails so that the led rings will serve (in addition to the parking and brake lights) as the turn signals also. I also want to rewire the turn signal bulb sockets to run in conjunction with the reverse lamps so that in the end I will have 4 reverse lamp bulbs, instead of turn signals in the outsides. I kno I need some relays i just need help knowing where and how to wire them. Thanks for your help.
Old Dec 10, 2007 | 05:43 PM
Cdg2125's Avatar
It's really just a pain in the a$$ to do that. Requires running the wires all different places and relays and all. Get rid of the altezzas. Otherwise you need a relay to connect the brake lights to and run the blinker wire to the relay to turn off power to the brakes when you need them as blinkers. The turn signals just need to be wired to the reverse lights.
Old Dec 10, 2007 | 05:45 PM
Conrad283's Avatar
I need a truck
Originally Posted by tvis
^ The winn4r
You sir are 110% correct
Old Dec 10, 2007 | 09:27 PM
2themax99's Avatar
thanks... well does anyone have a set of retro led tails laying around that they are willing to sell me? if so you can email me at devin.lam.07@cnu.edu
thanks
Old Dec 10, 2007 | 10:26 PM
Cdg2125's Avatar
thanks
what do you mean retro tail lights? Like real LED tails that some of us made? Nobody will have some laying around haha. You can ask someone to make them. One guy on here is making them and hoping to sell them but his style is not the same as Wizards, or mine in my link. He has many leds instead of individual lines. Depends what you want and how much you'll pay. I might be willing to make a set but it will cost over $300 because of time involved.
Old Dec 11, 2007 | 06:19 AM
2themax99's Avatar
cdg2125 pm sent
Old Dec 11, 2007 | 10:40 AM
93altima's Avatar
Turbo 4th Gen
wait iam serioulsy lost so we can take off the orange part in our tails????
Old Dec 11, 2007 | 11:30 AM
97SMG's Avatar
^^ No sir, you cannot. The orange is the actual lens on the 95-96 tails.
Old Dec 11, 2007 | 02:57 PM
93altima's Avatar
Turbo 4th Gen
damm
Old Dec 11, 2007 | 03:03 PM
LILMAN's Avatar
Thats f*cked up we can only paint our stock tails.
Old Dec 12, 2007 | 09:01 PM
max95q's Avatar
Well, I do have a set of 95-96 all clears already opened up. Still waiting to be painted to make the David L like 95-96 red/ clears. Im going to sell them. Let me know if you are interested.
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
JoshG
Sep 5, 2015 10:10 PM
