Clearing Corners (Headlights And Back)
Old Oct 4, 2007 | 04:37 PM
PimpCode323's Avatar
Tha Don
is it hard to take the orange film out from the head lights and the back if so anyone got a tutorial
Old Oct 4, 2007 | 04:39 PM
Graem's Avatar
there are tutorials for doing the tail lights but as far as the fronts check the classifieds or ebay dood
Old Oct 4, 2007 | 05:03 PM
MOHFpro90's Avatar
www.vqpower.com
Old Oct 4, 2007 | 05:21 PM
metallic97gxe's Avatar
Master Will
what exactly do you want to do? I will help you all I can...
Old Oct 4, 2007 | 06:44 PM
Tha Don
i want to clear both my blinkers front and back take the orange film off
Old Oct 4, 2007 | 06:47 PM
pmohr's Avatar
No more Maximas...
Take the orange film off of your headlights? There is none...
And if you mean the blinkers, that's molded orange plastic, not clear with an overlay. You need clear corners.
Old Oct 4, 2007 | 07:16 PM
Master Will
your front blinkers are called front bumper lenses the stock ones which you have are orange you just need to buy soem aftermarket clear front bumper lenses and in the rear your tail lenses are stock with the orange reflector in it you can just buy some red clears or some altezzas to upgrade your tails lenses here is a Ebay link for Maxima clear items...holla at me...
http://search.ebay.com/maxima-clear_...Zm37QQfromZR40
Old Oct 4, 2007 | 07:49 PM
wetzelman1's Avatar
tailights
1. Heat up taillights in oven, 350 degrees for 10 minutes, keep an eye on em.
2. Remove outer casing slowly.heat will have melter glue
3. Remove orange plastic and replace with clear plastic of your own making (home depot generic light covering plastic)
4. Replace new cleared lenses on tail. If it's done fast enough the glue will just re-attach.
Old Oct 5, 2007 | 03:02 PM
Tha Don
are u serious u heat it in the oven it wont mess up or anything
Old Oct 5, 2007 | 05:03 PM
99grnmaxgxe's Avatar
Not unless you leave it in there too long.
Old Oct 5, 2007 | 07:35 PM
NineOhSE's Avatar
Or not long enough..... Mine didn't heat up enough and cracked. Luckily it didn't break too much.
Old Oct 5, 2007 | 07:45 PM
wsrivers's Avatar
Theres a how to summary for each generation Max. You should find a how to for your front lights there. I found it for my 5th generation and I saw a link for How to's for the 4th generation.
Good luck
JRod28
Dec 29, 2023 09:56 PM
DZN13
Aug 24, 2015 11:00 AM
wingsfan24
Aug 15, 2015 07:35 PM
yat70458
Aug 3, 2015 01:16 PM
