Columbia, TN. 89 Maxima SE 5spd, Black with Gray interior
Old Oct 8, 2007 | 01:15 PM
JstAntrRoky's Avatar
For sale is my 89 SE with the 5 SPD. I had put an engine in from the junk yard and after giving it the once over and cranking it I had forgot to tourque the timing belt tensioner. This failure happend at idle. The Engine was replaced due to a lower end knock in the STOCK engine at 304,000 miles.
Here is what I have done to it. 6 brand new NISSAN fuel injectors, WARPSPEED Y pipe, the distributor is newer along with the crank position sensor. The tires are newer but due to the amount of time the veh has been sitting more then likley have flat spots. Veh could be towed on them. There are JL audio componets in the rear deck. It has an AWIA CD player. I have the cylinder heads already off of the old engine and would come with it. I have various trim peices that would come with it. The interior is in decent condition for being an 89.
To make the vehicle run it would the cylinder heads reworked or replaced, and the Clutch Slave cylinder replaced or rebuilt. The engine was running very well with no lower end noise at start up before the timing belt slipped. The rear main, crank, oil pan, and cam seals/gaskets have be replaced. All of the motor mounts are in great condition or have been replaced.
This was my project car but I'm moving so I have to let it go as I can only tow one vehicle behind a U-HAUL.
Pictures will be added. The vehicle does need some body work and possibly a driver door if you don't want to try to repair it.
Please let me know if you have any questions...
$1000.00 OBO
Pictures to come.
Old Oct 9, 2007 | 10:02 AM
bump
Tbone3944
Sep 29, 2015 09:04 PM
MikesChevelle
Aug 14, 2015 12:31 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
silver_i35
Aug 3, 2015 11:23 PM
