Traction Torque Steer
Old Nov 15, 2007 | 04:30 PM
LandsEnd's Avatar
Don't you get better traction on a front wheel drive car then a rear wheel drive car since the weight of the car is heavier up front where the engine is?
Whats this torque steer issue with cars with too much power should be rear wheel drive. Either way the tires spin even more so I would think in the rear where its lighter.
Drove my car today in the rain. From a stop sign tap the gas abruptly up to around 2000 rpm's, and the brand new RSA's spin, and spin until I let off the gas some. (Ridiculous no traction at all on brand new tread from my recall. Your right.)
Old Nov 15, 2007 | 04:41 PM
NismoMax80's Avatar
SuPeRmOd
fwd is trying to move the car and steer. that makes it inferior in handling to rwd. doesn't matter where the weight is located so much, especially since cars are closer to 50/50. plus weight shifts back when accelerating. you can feel the front lifting if you launch hard enough.
RSAs are terrible traction wise. even worse in wet conditions.
Old Nov 15, 2007 | 05:38 PM
gen2000's Avatar
All new tires have mold release chemicals on them that take a few hundred miles to wear off before you get full traction.
Any wet or damp street will make it much easier to spin your wheels. front or back.
The 04 Max is producing in excess of 200 ft/lbs of torque at 2000 RPM.
Any of these factors make it easy to spin your tires no matter what brand.
Old Nov 15, 2007 | 06:50 PM
NmexMAX's Avatar
dot dot dot ...
Unequal length shafts (CV axles) is partly if not mot importantly responsible for that. GM seems to have the secret, but they don't share it, or of they do, no one follows.
Old Nov 15, 2007 | 06:52 PM
Mack's Avatar
Really? In what vehicles?
Old Nov 15, 2007 | 08:44 PM
BadBlackMaxSL's Avatar
Doesn't the new Altima have the new setup that has eliminated the torque steer?
Old Nov 15, 2007 | 09:26 PM
SmokeNismo's Avatar
I think you're right. Most new FWD dont have as much if any torque steer. I know my brother 07 v6 camry doesnt torque steer at all.
Old Nov 15, 2007 | 09:58 PM
!PrjctMax!'s Avatar
Maybe he doesn't have enough torque
Old Nov 15, 2007 | 10:03 PM
DeusExMaxima's Avatar
Old Nov 16, 2007 | 05:07 AM
bdmaxima's Avatar
this is a little off topic but i think i would prefer a a rwd. i had a lil problem yesterday with my car spinning out on me on this curve on the highway (thank god nothing happened to me or the car). I lost grip in the back and basically spun out, doubt that would have happened with a rwd.
Old Nov 16, 2007 | 05:10 AM
Mack's Avatar
Yeah, my GF has an '06 camry and it's not exactly a ball buster. LOL. Great car though.
Old Nov 16, 2007 | 06:13 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
...................................LOL, you bad...
Old Nov 16, 2007 | 06:16 AM
chernmax's Avatar
I've taken some pretty good 50-70mph curves and my car sticks like rails, maybe you should consider some suspension/tire upgrades...
Old Nov 16, 2007 | 08:46 AM
QwikKota's Avatar
You can spin out anything if you try hard enough. Weight distribution has more to do with that than location of the driven wheels. As does suspension setup etc. If you enter a turn sharply and hit the brakes you will break the rear end loose no matter what you are driving. A rear engine Porsche will do 360's if you do that. Esp the old ones. You always want to brake coming up to the turn then go through it slightly on the gas to plant the rear tires and get ready for accelerating once you are out of the turn. The not hitting the brakes in the middle of the turn is more of a safety thing than a racing technique. On a wet road it can save your butt.
Old Nov 16, 2007 | 09:12 AM
NismoMax80's Avatar
SuPeRmOd
Old Nov 16, 2007 | 09:22 AM
bdmaxima's Avatar
true but being young, reckless, and speedy gonzalez i decided to go against a mustang right after it rained since i thought the car could handle that turn but guess i was very very wrong.
ya i was thinking about that when i spun out like damn i should have bought those springs from you, they could have helped. but i decided just to save my money up for coilovers.
Old Nov 16, 2007 | 09:29 AM
NismoMax80's Avatar
SuPeRmOd
WTF wet roads?
Old Nov 16, 2007 | 09:40 AM
bdmaxima's Avatar
ya i know
Old Nov 16, 2007 | 12:29 PM
SmokeNismo's Avatar
LOL, I know that's just a joke. those cars have about as much torque as our Max's though, according to factory spec sheets.
Old Nov 16, 2007 | 01:09 PM
Machinist's Avatar
Just hit the throttle when it's little damp in curve with RWD, let me know how many times you spin around
Old Nov 16, 2007 | 01:50 PM
Mack's Avatar
Can you show specs of the 4cyl version?
Old Nov 16, 2007 | 02:32 PM
NmexMAX's Avatar
dot dot dot ...
2.4-liter DOHC 16-valve
VVT-i 4-cylinder
158 hp @ 6000 rpm/
161 lb.-ft. @ 4000 rpm
But why?
Old Nov 16, 2007 | 03:47 PM
betep's Avatar
Just don't tell me that You don't wish Your maxima would be RWD.
About hitting throttle: TCS will help You in both situations RWD and FWD, putting TCS aside - You wouldn't want to hit throttle in FWD either - You'll be going straight regardless where You turn Your wheels, or I'm wrong?
Lots of people says that FWD is better in a snow - I partially agree, BUT if you lost traction in FWD- bye, bye - You have on control till the car slows down and your front tires start to grip. in RWD with a little knowledge and driving skills You can regain traction.
Just my 2c.
P.S. If they made M35 - 6speed - I wouldn't be driving maxima.
Old Nov 16, 2007 | 04:20 PM
RHMax's Avatar
Newbie just Registered
Tire size and suspension setup, but not on all GM cars. The Impala SS has massive torque steer, but the Gran Prix GXP has much less on the same platform/engine. Read it in a car mag, plus these are among my other regular rental cars.
Old Nov 16, 2007 | 04:28 PM
RHMax's Avatar
Just my 2c.
TCS doesn't help if both wheels drive wheels lost control and spinning euqally, regardless of FWD or RWD.
I've spun out in a RWD w/ TCS on in the rain, and I wasn't going fast either. Dynamic control is the way to go in wet/snow.
Old Nov 16, 2007 | 04:38 PM
TCS works by retarding the timing, according to Tadashi at TS.
Old Nov 16, 2007 | 04:48 PM
NmexMAX's Avatar
dot dot dot ...
He's wrong.
Old Nov 16, 2007 | 05:41 PM
RHMax's Avatar
He's wrong.
While TCS on, the ECU does retard the timing for less initial torque. It does not adjust the timing after the wheel/wheels slip. It uses either brakes or throttle to control wheels after slip is detected
Old Nov 16, 2007 | 05:42 PM
NmexMAX's Avatar
dot dot dot ...
TCS Function EFS004FM
Spinning of the drive wheels is detected by the ABS/TCS control unit using inputs from the wheel speed
sensors. If wheel spin occurs, the drive wheel right and left brake fluid pressure control and engine fuel cut
are conducted while the throttle value is restricted to reduce the engine torque and decrease the amount
of wheel spin. In addition, the throttle opening is controlled to achieve the optimum engine torque.
No timing.
Fuel/Brakes/Throttle
Old Nov 16, 2007 | 08:10 PM
SmokeNismo's Avatar
I believe in our cars when slip is detected, only the throttle is cut right?
Old Nov 16, 2007 | 08:12 PM
NmexMAX's Avatar
dot dot dot ...
Hmm, take a look at my post, it's from the FSM.
Old Nov 16, 2007 | 08:40 PM
Machinist's Avatar
Just my 2c.
Sorry, I will tell you "I don't wish my Maxima was RWD" In the rain or in the snow I prefer the superior traction of FWD. But I do wish my Maxima FWD was a LSD
Old Nov 17, 2007 | 06:05 AM
bdmaxima's Avatar
i don't think so from times when i would just do a churp and the slip alert would come up my throttle is still high till it gets grip again
Old Nov 17, 2007 | 11:05 AM
NmexMAX's Avatar
dot dot dot ...
I guess no one read my post?
Old Nov 17, 2007 | 07:33 PM
SmokeNismo's Avatar
I read your post. =)
to bdmax, you definitely get a loss of power right after the tires chirp though, you can really feel it up till about 3500rpms is where the power starts to come back. knowing how to launch it without the traction control could give you better results in terms of hard acceleration.
Old Nov 17, 2007 | 08:21 PM
kevin007's Avatar
Timing is also pulled out so detenation does not occur. Nissan would not cut fuel without cutting back on timing.
Old Nov 17, 2007 | 08:29 PM
Hilbe's Avatar
I still want to know if its possible to get TCS after the fact. My Maxima didn't come with it, only feature I really wish it had... Seems like I could just swap out the ECU...
Old Nov 17, 2007 | 11:13 PM
!PrjctMax!'s Avatar
And add a switch/wiring/fuse?
OR, how about you use your foot+common sense .02
Old Nov 17, 2007 | 11:55 PM
NmexMAX's Avatar
dot dot dot ...
ECU+Key+dealer reprogramming key + add switches @ dash.
Old Nov 18, 2007 | 05:51 AM
Hilbe's Avatar
How much do dealers usually charge for the reprogram?
Do I have to buy a new key? I am seeing some used ECUs on eBay for $130 or so.
