FS: 1995-SE, 5spd, 234k, 1 owner, Rome, GA $3,500 OBO
Old Nov 25, 2007 | 11:58 AM
Big EEEE's Avatar
1995 Nissan Maxima SE – 5 speed
One Owner – Me – I bought this car new!
Price is $3,500 OBO (no sales tax)
You need to drive this car! It has 234k miles, but it has been well maintained and you will be able to tell the difference when you drive it.
OPTIONS:
Arctic white with black leather
Power driver’s seat (one of the four motors won’t work)
Bose sound system with CD/AM/FM (cassette will not play)
Sunroof (pops up, but will not slide back–needs tracks replaced–cheap parts/mucho labor)
Auto climate control (you set the temperature you want on the dash)
Power locks, windows, brakes, steering, seats
Factory alloy wheels (saw blades)
Factory fog lights
Factory spoiler
Factory floor mats in almost new condition
Factory mud flaps
Factory air dam mounted to sunroof
Factory CD Changer in the trunk
Tilt steering
Keyless entry (yes I have the working key fob with the car)
Dash is all black (no wood grain)
MAINTENANCE:
Oil changed every $3,000 miles at Nissan here in Rome, GA
There are no modifications to the body, engine or audio system (just like from the factory)
INTERIOR CONDITION:
Very nice interior and very clean, no odors (non-smoking)
Bose stereo sounds great
All gauges work and are lit at night
The car has a nice quiet and comfortable ride
Boots on shifter and brake are worn, driver’s seat slightly worn (typical)
A few rough spots on the leather steering wheel
MECHANICAL CONDITION IS EXCELLENT:
Within the last 8 months I have replaced: Battery, starter, driver’s side axle, air filter, transmission seals, front and rear struts, tires, knock sensor, O2 sensor after the cat, clutch master cylinder, 3-coil packs (back side), alternator and water pump. (~1000 miles in the last 8 months)
Smooth transmission operation - fresh fluid, seals and input shaft and through-out bearings.
Clutch pressure is excellent (you won’t have any problems with this clutch)
Axles are in good condition (no knocking or split boots)
No check engine light (all ECU systems are functional)
Air conditioning is ice cold and the heat works fine
No oil or fluid leaks
Everything works (except as mentioned above)
Fresh oil change and filter…buy and drive!
EXTERIOR CONDITION:
Small scratches, dents and dings consistent with age
Right front fender has small dent and some small depressions/dents in the middle of the hood (these are not so noticeable since the car is white)
TITLE AND HISTORY
VIN-JN1CA21DXST670148
I have clear and clean title in hand
Front and rear bumpers have been replaced by reputable body shop
This car has clean history, no major accidents (all VIN’s match - doors, fenders, hood, trunk, body)
Kelley BB private party values: Excellent $3,410 Good $2,995 Fair $2,485 (w/high miles at 234,000)
Call Erick at 706-232-5669 (home after 5 pm)
or 706-676-0479 (cell)
Old Nov 27, 2007 | 03:04 PM
Big EEEE's Avatar
Pics at
http://atlanta.craigslist.org/car/491422118.html
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Stagnet04
Oct 11, 2015 08:16 PM
ef9
Oct 4, 2015 08:43 AM
bernyp
Oct 2, 2015 10:10 AM
