Another Offset Question!!!
Old Dec 1, 2007 | 01:15 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
The rims are 19x8 in the front and 19x9.5 in the rear. The offset it 20mm all around.
I am running 19x8.5 in the front and 19x9.5 in the rear right now. Witha 40mm offset. ( 2003 Max )
I know that it will stick out about 14mm in the front and 20mm in the back. However, I don't know how far it will stick out from my fender, if at all. I have seen pics of this set up on a 4th gen and it sticks out just a little. I know the 5.5 gen fenders are a little more forgiving so that is where the question comes in. How far will they stick out, if at all?
I searched and came up with 2 5.5 gens that ran this set up but neither of them have responded to their pm's. If you know whether or not this set up will work on a 5.5 please let me know. Thanks in advance.
Old Dec 4, 2007 | 12:26 AM
MrDicks95SE's Avatar
Offset Is Everything.
i say do it. i think it'd be really flush with the fenders, especially in the rear.
Old Dec 4, 2007 | 01:08 AM
00SEMAX19's Avatar
Fronts should probly be fine but rears will probly rub over bumps. Just think about taking your rear wheels and adding a 20mm spacer behind it. With the fronts being 8" instead of 8.5" the difference would be slighty less, I would imagine it would be like having a 15mm spacer on the front of the wheels you have now.
Old Dec 4, 2007 | 12:21 PM
nothing a stretched tire and fender roll cant fix.
Old Dec 4, 2007 | 07:12 PM
Ammi's Avatar
350 Detroit Muscle
If you are slammed, you will rub especially if you have people riding. You should roll your fenders
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
