D2 Coilovers Questions...
A33 D2 coilovers use allen bolts to clamp down the monotube and they are really annoying... If I dont tighten them as much, they get loose. And if I tighten them a bit over, they make noise...
So I was just wondering if anyone has convert to lock ring instead.. or is it possible?
And also... I tried searching a bit but the thread was like a year old, so I didn't wanna bump that... I just want to ask if a good preload is to hand turn the lock rings high enough so the spring cant move
Thanks... much appreciated!
So I was just wondering if anyone has convert to lock ring instead.. or is it possible?And also... I tried searching a bit but the thread was like a year old, so I didn't wanna bump that... I just want to ask if a good preload is to hand turn the lock rings high enough so the spring cant move
Si senor... 100% sure these damn allen bolts are slowly unbolting themselves causing "popping" noise. Gonna try some threadlock and if it doesn't work, then Im gonna order a set of lock rings...
Made the ride more comfortable.
I would not put ANY pre-load on D2's.. They too stiff right out of the box.
I also thought about getting a longer bolt so I can screw in a nut at the end to act as a locking device, but the D2 bolt pattern is all weird... If the threadlock is not gonna work then I guess theres no point of me wasting time jacking car up and stuff... time to order a set of lock rings
If you tighten the bolts a lot and the mounts make clicking noises, you just have to tighten the bolts further. The tighter they are, the louder the clicks will get, but they will become less frequent because the friction is higher: the mount won't move as much, but when it does, it'll pop louder. If you keep tightening, eventually you'll reach a point at which the mount doesn't move at all. That is true for anything that clamps a lower mount on a coilover, including locking rings.
The only problem with the bolts is that you have to tighten the HELL out of them to get to that point. Occasionally that will cause the threads to strip or the bolts to break. Locking collars are a lot more durable, but you still need to tighten the hell out of them, usually by banging on the collar wrenches with a hammer (no joke).
When the car is on the ground, the suspension just compresses through the one inch gap until it gets to the spring anyway, so there's no difference in preload between the way you have it and just-barely-snug against the uppper hat. You are just one inch of travel closer to bottoming out your dampers, with nothing to show for it.
Also, if your suspension ever does extend to within one inch of full droop, the spring might not be neatly aligned with the upper spring isolator. If it's out of alignment when the suspension compresses, the spring won't just slot back over the isolator like it should and might damage it in the process.
All that does is reduce your suspension travel and slowly shred your upper spring isolator. Trust me, I know better than I'd prefer to admit.
Never had one problem with mine and it was run that way for over two years & 20k miles...
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
