Diameter of signal on 5.5 gen headlights
Any one know the diameter of the amber turn signal on 5.5 gen headlights?
Or if someone has a set apart could you measure it? Info is needed for a upcoming project, trying to minimize down time. Thanks
I am planning on removing the amber lens, but wanted to replace it with something different, other than the frosted or linear diffused lens that other orger's are using. The how-to was good info, i just need the diameter too. Thanks
3" Diameter on the front side. 3.5" on the rear, rear has a 1/4" lip on each end for mounting in the clips.
I actually just removed it completely, and dremeled out the parking light lens. Will throw pics up when I get a chance.
i dont understand. Is the lens tapered?
(amber signal, front) 3.0"f to 3.5"b I'll just wait for the pics and i can see for my self. thanks
Yeah just be careful dremeling it. It took me a while only because I didn't have the proper attachement. But I eventually cut it. Trick is to trace well. And take your time and be sure to grind it evenly all the way around. And when you think you got close keep trying to fit it inside the housing, grind some more away, untill its just right.
MAXSE5SPD
Sep 17, 2022 04:00 AM
sdotcarter
Sep 2, 2015 09:53 PM
