almost got hosed. thought needed new alt but was belts/
last September I had a local mech change out my belts. by October everytime I started up the car I had a horrible squeal that sounded like belts but also sounded a bit like some bearing was going out. in dec I had the mechanic check the belts and he said the ps belt was fine but he could not adjust the main belt any tighter and said the noise might be something else. now during this time in the dead of winter I wanted nothing to do with changing an alternator or even checking pulleys etc. so last sunday I decided to do some reading here on the forum and found out the specs for belt deflection.
turns out the nut job who installed the belts met with some resistance on the tensioner bolt and was scared to go further. I wd40 that sucker and 10 mins later the tensioner is 4 turns past where it was and a week later I have not heard any noise at all. before this I heard it at every startup.
no. The belts use a defelection spec. Meaning you should not have more than x amount of deflection between such and such distance. A general guide line is that the belts should NOT be able to turn or twist past 90 degrees with your fingers.
O_____________ |_____________O
Pulley.....Belt.........Belt.........pulley
if that diagram makes any sence....
. That's exactly why the nut job didn't go any further. Good thing yours turned out good.
TonyJr
Aug 20, 2015 12:14 AM
Superbform
Aug 11, 2015 08:10 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
MikesChevelle
Aug 6, 2015 11:36 AM
