Car shutting off
Old Mar 25, 2008 | 04:26 PM
CreativeDesignz's Avatar
Car shutting off
Ok fellas, this just recently started. No CEL's, oil recently changed...whenever i start the car first thing in the morning i press the brake pedal and put it into reverse the car stalls dead. If i dont put my foot on the pedal and just switch it to reverse it does not do this. Only happens in the morning and goes away in about 20 seconds after the car is warmed up. Other than that there is no way to duplicate the problem. Any suggestions?
Old Mar 29, 2008 | 12:13 AM
jdmkuruma's Avatar
hmm my guess is that your maf sensor is starting to go bad.
Old Apr 16, 2008 | 06:35 PM
qUiCkGeNz's Avatar
I, too, am also experiencing this. Funny thing is I really didn't worry about it until today when, also, in the morning this occurred to me. Previous to today, it would happen occassionally and instead of stalling completely, the vehicle would stutter and would eventually return to normal RPMs. We'll see how it is tomorrow when I try to start it again. Anyone else have any comments regarding this? Any votes supporting the idea that the MAF sensor is the culprit? Thanks.
-Thomas
2001 Infiniti I30
Old May 11, 2008 | 07:36 PM
maximomo's Avatar
If you want to see if the MAF sensor is at fault--unplug it before starting your car. It will run without it but don't do it for long. Plus--it will set a code and light up your CEL. If the car still does it with the MAF unhooked-it's could be a vacuum leak, bad ground connections or just about anything.
How does the car run otherwise? Any rough idle, hesitation on acceleration, stuff like that?
Old May 22, 2008 | 04:18 AM
revvv's Avatar
lol i have this problem too.... just play with ur idle screw theirs a screw head look alike thing
Old May 22, 2008 | 04:41 AM
maximomo's Avatar
NO! DON'T adjust the idle speed screw *****-nilly and "play" with it!
Not unless you also want to screw up your gas mileage and performance.
There is a proper procedure for adjusting your idle and it is controlled electronically after that. If you mess with it and don't use the proper procedure you're an idiot.
Aside from the fact that this has NOTHING to do with the problem you are having.
I would have your battery tested. I know this sounds odd but these cars do some really weird crap when a cell in the battery is dead or dying. Mine was blowing the 30A ignition fuse on startup--replaced the bad battery and the problem went away.
Old May 23, 2008 | 11:27 PM
Luigi38's Avatar
Check you battery, alternator, fuel filter, pcv valve, spark plugs?
is the knock sensor good...if it's been broken for a while it could mess things up
Hondarydr
Dec 30, 2024 06:15 PM
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
erniel
Aug 8, 2015 09:32 AM
