Odometer overspeeding
Yesterday, after fueling I reset the odometer (trip meter) and noticed that after covering just ~1 mile it is showing as 17 miles!
How to correct this problem? Anyone faced this problem?
My Maxima never stop surprising me these days
-MM
-MM
is your speedo working correctly? I am guessing its not just the trip meter, but both meters...
if it is, this may(dunno) fix the problem.go to the junk yard. pick up a gauge cluster from a 3rd gen(shouldnt matter what model, but to be on the safe side and if possible, pick one up of the same trim/year. and make sure the trip meter sets back to zero if possible). take it home, disassemble, and find the motor for the odometer(small little thing...) disasemble the odometer(or since the milage is probably way off now, pull the entire assembly.) now take apart your dash, and remove the gauge cluster. take your gauge cluster apart and replace that motor(or assembly). put back together, and reinstall gauge cluster, take a test drive. if it works, reassemble the dash, and have fun!
couple of notes:
1. if you swap over the odometer assy, you will have to note that the miles are off on the title if/when you sell it.
2. if you take the test drive with the dash apart, make sure to plug the hazard switch so you have blinkers.
3. while you have the cluster out, might wanna check for burned bulbs, and replace them if needed.
4. this can be a little time consuming, and frustrating(the first time...) but remember how you did it, and have fun!
wouldn't that have been a little obvious? the partial mile is on a white wheel, while the other digits are black wheels...(then again, some of the things ive seen.....and done...
couple of notes:
my trip is really messed up as well...it goes a couple hundred miles after about 4 or 5 real miles when i reset it....then when it hits 400 or 500 some odd miles it will stop all together, lol....all other gauges and odd. work just fine and dandy though...thee car is old my friend.
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
