6speed Hesitation after all common fixes?
02 6speed
- Replaced motor mounts with ES mounts, replaced 02 MAF with 03 AM600 MAF, and reprogrammed/updated ECU at dealership. Recently tuned-up (new sparks, PCV, fluid flushes). Car still bucks hard (will try to get video of this soon so I can show you what I mean). Any ideas on what it could be?
When does this "buck" usually happen? My car has a tendency to "buck" in a low gear (1-3) at around 3-4k RPMs when pressing and releasing the throttle. I assumed it was just the late/early/over-estimating/under-estimating drive-by-wire system.
It is very noticeable in lower gears. I let off the accelerator pedal during smooth, slow acceleration and the car will buck back and forth. For example, 2nd gear, 2-3k RPMs, constant speed, the car will buck forward off the pedal, and will continue to do so during deceleration. If it is the e-throttle, is there any way to smoothen out the signal? I've done all the relearns, but if the car needs to have it reset every so often, it becomes kind of a ridiculous task.
oh so it's ok after relearn for a while and then it shoots banks again?
If so just change the throttle body. Sometimes when we couldn't relearn we just changed the TB and after that it took it like a champ.
I suspect flap does not open smoothly/fast enough. This would be next thing to do....
Maybe you have a bad ignition coil?
It may not be necessary a dirt issue but a failed component i suspect
I had this happen but only once when I first got my car.
I let it sit over night and it fired up running smooth the next day.
this might be a dumb suggestion, but did you clean the MAF before putting it in?
could have some dust/lint on it from storage?
I think its the coils.
adrenaline_rush_fanatic, the MAF was brand new, and even if there was dust/lint sitting there, it wouldn't be for long. The car continues to have hesitation after it starts up, no matter what the temperatures are. I think the word "jerky" as in the car jerks/bucks back and forth is better than the word hesitation.
jerky could be due to coils. You should get a misfire code. However it could also be due to a vacum leak. Have you connected the MAF sensor well and tightened all the clamps after the sensor?
Also if the intake plenum gasket was not replaced or installed properly it could leak too
If you bring it in they could check air/fuel mixtures and know if you have a leak. Quite easy for an experienced tech. Bring it in to a different dealer if they can't fix it after all that $$ you put in.
Maximeltman
Sep 28, 2015 07:19 PM
