Grinding from engine area when starting. Flywheel?
Sounds like teeth grinding against the flywheel. I bench tested the starter and it's fine. Reinstall and same grinding... and then it started! Went 3 days, no problems, and this morn same grinding. Bench test again, no problem.
Flywheel teeth looks fine, but I couldn't get a flat screwdriver in there w/enough torque to turn it and check the rest of the teeth. Just wondering, what's the likelihood of a bad flywheel or loose flywheel?
Dr J
Dr J
Swap in another used battery, many sparks fly as I attach the neg wire, so I quickly detach the wire. Interesting thing: key is in my pocket, it's in Park, and the starter wound up for the instant I attached the negative... maybe that's why it sparked? But why would the starter try to go when there's no key in the ignition? I'm sooo puzzled. I'd go get another battery, but I've already rode my bike 5 miles to get the starter, and not feeling like toting the battery 20miles round trip to Sams to get pro-rate.
Dr J
next time you want to inspect the flywheel or rotational movement turn the crank pulley bolt with a socket (clockwise or it might break loose and youll have to retorque it) note*(the crank will be hard to turn at certain points in the rotation )also pull the drive belts and spin each pulley by hand to rule out siezed pumps or pulleys
Dr J
although i have "mcgyvered"some things ,but i try to stay away from "ghetto rigging"
sometimes i dont even want to start my car because... well i just feel bad for it.. lol. its a terrible sound like metal to metal sometimes ill stop cranking right away than try again. like makes the car shake kinda... sux
it just doesnt start up smooth(new fuel filter) its never the same idk
,dealer said you need both new converters,friend got sad,i read in owners warranty that it was covered for eight years,friend gets both new for free
Dr J
Mar 12, 2020 12:06 AM
97_GXE
Sep 15, 2015 06:47 AM
trungg86
Sep 4, 2015 04:58 AM
