NEED HELP(I know what parts I need & their #'s) using courtesynissan.com.
I have identified the part numbers on courtesynissan.com for my 2000 gxe maxima
Bolt-Hub - 40222
http://www.courtesyparts.com/betasit...3-p-46192.html
Lug Nut - 40224
http://www.courtesyparts.com/betasit...ml?cPath=1956&
I will need atleast two lug nuts and bolt hubs. One lug and bolt hub has already been broke trying to rotate my tires. Another lug on the same wheel is stuck that I am going to have to break off.
QUESTIONS:
1)ARE THE PARTS ABOVE FOR A SINGLE PART? Should I order to of each or are they a set to do one wheel?
2)HOW THE HELL DO I ADD SOMETHING TO MY CART?
3) CAN I GET THESE PARTS LOCALLY AT AUTOZONE, ORIELY'S, ETC
4) IS IT SAFE TO DRIVE WITHOUT ONE LUG NUT? My car makes a clunking noise and I can feel it if I don't have pressure on the wheel from either acceleration or braking? This is my only ride!
Bolt-Hub - 40222
Lug Nut - 40224
QUESTIONS:
1. Nuts and bolts are sold individually.
2. Click the 'add to cart' button, only these aren't available through Courtesy anymore. As it says.
3. Yes.
Here are the real part numbers (Courtesy's 'part numbers' are specific to them only, and you listed only part codes):
4. It'll be fine.
3. Yes.
4. It'll be fine.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
