Performance Fuel Injectors
Old Jun 4, 2008 | 10:39 PM
darkman
Yo im looking for links and suggestions on fuel injectors no oem stuff python,venom,nismo or any other PERFORMANCE 25CC OR MORE INJECTORS
for 96 gxe 4th gen
Old Jun 5, 2008 | 06:15 AM
Flava_24/7's Avatar
Boosted Panda
Why do you need something above stock?
http://www.deatschwerks.com/catalog/
Many are running these injectors. I have a set of 550cc Im going to install in the next week or so.
Old Jun 5, 2008 | 07:22 AM
mtrai760's Avatar
'Trynna' is not a word
Originally Posted by darkman
PERFORMANCE 25CC
Performance 25cc injectors?
Old Jun 5, 2008 | 08:00 AM
95maxdvt
Ebay find some 300Z injectors.
could be wrong but believe maxima injectors are at least 180cc
300Z 370cc
anybody plz correct me if im wrong
Old Jun 5, 2008 | 08:37 AM
darkman
im sorry i meant 250cc sorry but still will a 300z injector fit
Old Jun 5, 2008 | 08:42 AM
Flava_24/7's Avatar
Boosted Panda
Yes they will. Im running them now. You will need something to control them though.
Old Jun 5, 2008 | 08:58 AM
darkman
what type of control what do i need and upgraded ecu or can i just get a flash
Old Jun 5, 2008 | 09:11 AM
mowgli29's Avatar
Horizontally opposed.
I know there's a thread with a good explanation on why using the z32 MAF and injectors works well together, but not seperately. I don't feel like searching for it or trying to explains it though...Maybe the OP should search BEFORE posting this thread?!
Old Jun 5, 2008 | 09:12 AM
darkman
and may i say ur maxima is one of the best i have ever seen in my hole life those headlights and tail lights are brilliant amazing u should patient that stuff FlaVA
Old Jun 5, 2008 | 09:43 AM
mtrai760's Avatar
Why do you want to run larger injectors? Unless your running some sort of power adder, ie Supercharger, Turbocharger, or Nitrous, there is no need.
Old Jun 5, 2008 | 10:20 AM
95maxdvt
i just replaced a stock maxima injector in mine looks jus like the rest and i noticed i have a Z32 MAF seems to work together fine.
Old Jun 5, 2008 | 10:37 AM
choray911's Avatar
The Crazy Azz Cracka
Dude! You need to work on your sentence structure.
Darkman: You really don't need anything bigger unless you are going to use a turbo, supercharger, or hose. Other wise you are just waisting your money. I have a set of 570 Deachwerks and have been thrilled with their performance. A set of Nismo injectors were almost twice as much with no guarantees.
Old Jun 5, 2008 | 10:45 AM
95maxdvt
How is this for structure?
One of my Injectors went bad so i ordered a MAXIMA injector.
When it came looked identical to others in engine, so im assuming there still stock....
When i bought the car there was another MAF in the trunk. I looked up the codes to one on the INTAKE and it matches a 300ZX.
So someone swapped the MAF b4 i had it, and not the injectors.
Result still works fine all i was pointing out, nothing about needing larger injectors.
Srry for confusion my fingers get lazy and sometimes brain too lol......
Old Jun 5, 2008 | 11:08 AM
Flava_24/7's Avatar
Boosted Panda
You sure its a Z32 MAF? It had the A32 plug on it? The Z32 has to be splice inot the A32's wiring.
You can also tell just by looking into it at the sensor and compare the differences in the two.
Old Jun 5, 2008 | 11:09 AM
95maxdvt
Def spliced try to get pics n post em
dont know was that way when i bought it
Old Jun 5, 2008 | 11:10 AM
Flava_24/7's Avatar
Boosted Panda
you will need something the control the flow rate.
If your NA you do not need larger injectors. They will do nothing for you but empty your pocket.
Old Jun 5, 2008 | 11:13 AM
95maxdvt
they are required for No2 tho??
was thinkin jus 50 shot could stock injectors handle it?
Old Jun 5, 2008 | 11:30 AM
mtrai760's Avatar
No, they are not required for nitrous. You don't need larger injectors for an NA car though.
Old Jun 5, 2008 | 11:53 AM
BLACKonBLACK98's Avatar
Former Vendor
is this across the board or could a major na build require larger injectors?
Old Jun 5, 2008 | 11:54 AM
kzoosho's Avatar
Im running 550's but only because i am boosted. I was running the stock injectors with 15+psi all last year.
Old Jun 5, 2008 | 11:56 AM
kzoosho's Avatar
For you, you can run larger injectors and pull fuekl thus adding timing for your n/a build and will help you that way but they arent needed at all.
Old Jun 5, 2008 | 12:00 PM
mowgli29's Avatar
DandyMax has had the most badass NA vq30 so far....and IIRC he put down about 270whp without upgraded injectors.
Old Jun 5, 2008 | 12:57 PM
darkman
all i want to know is names and places to buy no info thats all no one needs to know what i have going on i asked a question and ill i want in answers
Old Jun 5, 2008 | 12:58 PM
mtrai760's Avatar
Yeah, your gonna get great answers with that attitude!
Old Jun 5, 2008 | 01:00 PM
Former Vendor
i'm looking to beat that...
with my extremely limited knowledge of engine performance.
Old Jun 5, 2008 | 01:23 PM
choray911's Avatar
In that case do some f$#king research! This stuff isn't cut and dry, your needs change as modifications increase. How do you expect us to help if you remain aloof. Go screw yourself and your secret project.
Old Jun 5, 2008 | 01:24 PM
kzoosho's Avatar
Im with you now man. We try to help even tho search is free and we get that ? yea welcome to the org and well i wont help ya ever . kthanxbye
Old Jun 5, 2008 | 01:26 PM
mowgli29's Avatar
I didn't wanna say it!
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
