WTB: Clips, Connectors, and Covers.... oh my!!
Old Jun 10, 2008 | 06:41 PM
traxtar944's Avatar
Would be lost w/out the org
Well I want to get some under-hood parts that I've broken/lost/etc over the course of doing work on my car. Here they are as follows, make an offer.
*Wheel well plastic clips (All... like 10-15 of them?)
*Distributor cover (1)
*Ignition thing cover (1)
*Spark plug wire clip that mounts to the top of the intake (1) THIS SIMPLY SCREWS OUT! I didn't know that, which is why I need a new one.
*Wiring harness clips that hold the large mass of wires at the back of the engine (2)
*Piece that covers the bolts on the rear bumper.
---->(Must be removed by unbolting bumper. I can provide details on how to do this, it's actually easy.
----> It has little white clips that hold it down, and goes between the bumper and trunk)
*Knock Sensor connector (~8 in. wire with connectors)
*White Fuel Filler Door
Old Jun 10, 2008 | 08:14 PM
Chris Gregg's Avatar
Get Off My Lawn
I'm sure I have the rear bumper peice. Send me an image or a link to the Couresy Nissan page that has it identified. I may have some of what ever else you are asked about, but I'll have to check.
Old Jun 11, 2008 | 07:05 AM
mikekantor's Avatar
Good luck finding the wheel well plastic clips, I havent seen any generics that match up well, at the JY they are usually missing or busted.
In the end I just got some nuts, bolts, and large washers.
Old Jun 12, 2008 | 10:46 PM
traxtar944's Avatar
yeah but I don't want to do that... I don't want nuts sticking out into my engine bay, lol.
The trunk piece is 85080 (I think) and there's like 10 little white clips that hold it down. I need the clips and the piece. I'll also take 10 of the bolts that hold the bumper on. There are like 6(?) on the bottom that use a metal strip (85242) to disperse their force, and I think 6 on the top with the same metal strip-thing. The front bumper is held on with the same method.
Speaking of which, I'll also take the metal strip that holds on the bottom of the front bumper if you have it rust-free.
Old Jun 14, 2008 | 09:21 AM
Get Off My Lawn
Traxtar, I found several peices, probable have more but my garage is somewhat in disarray right now. Here is what I have found:
1. I have 85080 still attached to 85240 by the clips 85810e. However, the peices are held together by only 6, not 10 clips.
2. I have 85242 as well. I have found no clips for this peice.
3. I have a Dark Gray fuel door in perfect shape. Wrong color, but I've got one.
4. I have both front spark plug wire clips. You didn't specify, but there is one that mounts in the middle of the down pipe off the throttle body. The second is mounted on the throttle body beside the throttle position sensor.
5. I have the metal wiring harness holder that mounts near the PCV valve. It is in great condition; plastic still in tact.
6. If you REALLY need the bolts, I could track them down. I've got two boxes full of misc bolts, nuts, and washers. How many do you need, 10? Let me know.
Sorry, no distributor or ignition covers. Sorry, no wheel well clips (found 1). Sorry, could not find the metal strip for front bumper, but I'm sure I've got it somewhere.
I can have this stuff shipped via UPS or USPS by late next week (delayed due to work schedule). Let me know what, if any of this you want. I can provide pictures. Make me an offer.
Old Jun 15, 2008 | 04:14 PM
traxtar944's Avatar
Chris,
1) I only need 85080 and the 6 white clips (85810e). I do not need 85240.
2) I don't need that piece, thanks though.
3) I'll keep looking for a white door, since the basecoat could affect the color when it's repainted.
4) The clip I need screws into the top of the intake manifold. It is the first piece that the front three wires clip to.
5) If it's the black piece that holds down the main wiring, then that's what I need. I'll also need the one that holds on the other side near cylinder 1.
6) I REALLY need bolts that hold those metal strips down. They have a ridge to keep the strip in place that a normal threaded bolt does not have. Let me know if you can find those bolts and the front strip.
Thanks for the help, pictures are always nice for confirmation, and I'll give you $25 for everything. (plastic strip & 6 white clips, plug wire clip, 2 wiring harness clips, front bumper metal strip and some small bolts)
-Matt
Old Jun 16, 2008 | 06:38 PM
Get Off My Lawn
It will be this weekend before I can go garage diving again. If you can wait till then to get everything together and get pictures, I'm good with the offer (shipped?). In regards to the gas door, you could take it down to the primer or even the metal through sand blasting then paint it. It's such a small peice; just a thought.
Old Jun 16, 2008 | 10:28 PM
traxtar944's Avatar
I'll just wait untill you can get all the parts together. I have another guy looking around for me as well, so I'll let you know what's going on with that. As far as shipping is concerned, just let me know how much it is and if it's ridiculous then I'll cover some of it... but yeah that price was including shipping based on if it was around $7 or something.
Old Jun 19, 2008 | 04:13 PM
guitarpro_1st's Avatar
hey i have a white 92 se so i have a white gas door email me at guitarpro_1st@hotmail.com if you still want it
Old Jun 20, 2008 | 04:54 PM
Get Off My Lawn
Trax: YGM and images.
Old Jun 20, 2008 | 08:44 PM
traxtar944's Avatar
got it and replied. Thanx
Old Jul 7, 2008 | 01:00 AM
daftinnovations's Avatar
would you be looking for a jwt tuned ecu for vg30e 89 to 94 maxi ?
Old Jul 16, 2008 | 05:21 PM
traxtar944's Avatar
yeah, but it depends how much. PM me or email me at traxtar944 at gmail
Old Aug 22, 2008 | 12:51 PM
traxtar944's Avatar
update: Still need distributor cover, ignition thing cover, wheel well plastic clips, spark plug wire clip, a wiring harness clip, and a clip to hold on the rear window trim piece. Thanks!!
AaronL
Sep 23, 2015 03:34 PM
Johnny9595
Sep 16, 2015 07:20 PM
