got alignment done. but what to do about the rears...
the rear total toe is off by .17 degrees from the factory maximum of 0.43 degrees. the rear driver side toe off by .16 degrees. the rear wheels aren't adjustable though. so what do i do about this? or what can i do, do i just leave as is? is .17 degrees going to be somewhat bad for my tires?
well i'm just worried about uneven tire wear. all my tires esp the rear ones (since i rotated them) are heavily worn and i can't get 4 new tires at this time.
i might just have to run on my stockers for now
....guess i won't be selling these...
well if your getting uneven wear I guess it's worse than what everyone has told me! sorry for the wrong info in that case. if you can afford it you can always look into getting a camber kit and that'll straighten them up.
i have coilovers w/ camber plates but never really mess with the plates. i just adjust the knuckle using the elongated holes on the lower struts.
Agreed, 0.38* of toe isnt that big. Sure, it could be 'to spec' but it wont make that much of a difference.
Hey g4, you got an alignment with the Ksports? Do yours come loose and make your steering wheel off center?
Good so I wasn't wrong! I was afraid I gave wrong info!
yeh, i got it w/ the ksports. come loose as in where? the strut bolts?
i never experienced that problem. only time that it was off center was when i adjusted the camber and it was off by a lot.
hows your n/a project coming by the way?
Well, it seems that the lower strut locking collar comes loose, and that allows the lower strut mount to spin freely on the threaded body...I guess thats what it is. Anyhow, everytime I go around a corner, my steering goes slightly off center. Just have to tighten things...
N/a build is on hold until I can get more $$...haha. Granted, Im still trying to decide if I want to stay n/a or not....
for your project......3.5 swap + FI cough, cough
yeh, thats what i figured. just wanted to make sure if the toe being that off was a big issue to worry or not.
Mar 12, 2020 12:06 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
