1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Over drive : on or off while on track?
Old Jul 24, 2008 | 10:16 AM
J RO 9's Avatar
I'm planning on heading to a track this weekend with a friend of mine. We're just going to have some fun, and I want to see how my car is and compare it to my times/speeds after I start to mod it.
My question is: should I keep overdrive on or off while racing?
Old Jul 24, 2008 | 10:22 AM
maxima.713's Avatar
I think it doesnt matter.
Old Jul 24, 2008 | 11:34 AM
S1cTech's Avatar
i'd keep it off. cause it just makes ur tranni got nuch hotter and cause it to overheat. ir ur car needs it. it will prob use it automaticly but i doubt it. plus it might make ur times worse.
Old Jul 24, 2008 | 01:27 PM
khantalha+'s Avatar
keep it on, it doesnt make any difference
Old Jul 24, 2008 | 01:35 PM
NmexMAX's Avatar
dot dot dot ...
It does matter. Depending on your intake manifold, manually 1-2, then put it in OD.
Old Jul 24, 2008 | 04:15 PM
khantalha+'s Avatar
offcourse... if u have a 00vi...or even a mevi...
Old Jul 26, 2008 | 10:34 AM
wyche89's Avatar
i never noticed a difference when i had my auto.. try it both ways and see if you see a difference.. you'll probably get at least a few runs in to test it out
i was never good at the manually shifting an auto tranny... i tried it once, heard a loud bang, big jerk, and never tried it again.. lol
Old Jul 26, 2008 | 01:10 PM
OhOhMax's Avatar
There will be no difference, on or off, unless your car is actually shifting in to over drive while at the track, which I highly doubt.
Old Aug 6, 2008 | 07:04 AM
NmexMAX's Avatar
dot dot dot ...
There is a late 3rd gear hiccup that occurs when shifting manually (if left in 3rd). So if you do have an IM to support 'high' RPM shifting, best thing to do is shift into OD after you shift out of 2nd (essentially skip 3rd). This is assuming your car will not bounce off the limiter at the end of the track. And that would only be the case if you're running very small dia. front tires or you've changed your actual in tranny gear ratios.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
captchaos
Mar 15, 2016 12:18 PM
Maxie40
Sep 14, 2015 11:28 AM
