Multiple electrical problems..?
My buddy's '97 has slowly been degrading electrically. At this point, the windows, speedo, tach, A/C, and blinkers don't work.
It was also having a problem starting, so we replaced the ignition switch. This fixed the starting problem, but nothing else. All the fuses are fine. We're stumped, any ideas?
Did you check all the relays? I'm thinking that with so many problems you might have bad grounding that screws it all up. Or, I'm not sure on this one, you can have a voltage regulator messed up. My friend with a 98 had problems with all the back lights.
This sounds like it is a number of problems that are probably unrelated. Probably best to try to fix one problem at a time. Maybe try and fix the simplest one first. If they are related and you fix the easy one maybe you will get lucky and fix all.
Easiest to fix is probably what you call blinkers but what do you mean? Turn signals don't work? Hazard flasher does not work? Both? Try to give more detail about what is happening or not and maybe someone can give you some ideas.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
