Getting my 6mt tranny replaced with a 6th gen one
Was thinking about getting an HLSD and had a few questions
-Is HLSD locking or non-locking differential?
-Any good sites I can source out a tranny from?
-Any tips for buying this used tranny? In every possible way I would like to safeguard myself from getting a crappy tranny. Id just like to get some pointers here.
-Is the swap a 100% direct swap? Meaning, will I need anything else besides the actual tranny?
One of my boy's is going to do the actual swap in his shop.
Soo third gear is toast
...I can rev up the engine with the car parked put it in 3rd and it grinds 3/5 times. Not very good odds. I really wanted to get advice from those who have done this swap.
-I did a bit of searching and found even some 04 6th gen guys have a 3rd gear problem. Should I stay away from 04 trannies and get an 05-06? This is already a headache and I dont want to have to source out another transmission
One of my boy's is going to do the actual swap in his shop. Im hoping after this my 3rd gear wont give me anymore problems
...I can rev up the engine with the car parked put it in 3rd and it grinds 3/5 times. Not very good odds. I really wanted to get advice from those who have done this swap.-I did a bit of searching and found even some 04 6th gen guys have a 3rd gear problem. Should I stay away from 04 trannies and get an 05-06? This is already a headache and I dont want to have to source out another transmission
car-part.com is great for sourcing one. Like I said in the other thread. Look for one fron Canada. Nearly all the manuals there are HLSD. There's also a good chance it wont be dogged out since people there choose manual for more practical reasons than we do in the U.S. where mostly kids and hot rodders drive stick.
It's a direct swap. The only difference is where the shifter cables hook up to the levers on the transmission. You'll have to use one of the levers from your old tranny. It's no big deal at all. One bolt with no modification or anything. You'll see what I mean when you have it in front of you.
You wont need anything you don't already have.
One more thing. The final drive ratio is shorter on the 6th gen transmissions. That means every gear will turn a little higher RPM than it did before. It helps with acceleration but yor cruising RPM in 6th will be higher by a few hundred RPM.
Lower top speed in each gear = less time spent in each gear = more momentum-killing shifts to partially offset the higher torque multiplication. Shorter F/D's are at their best when mated with higher redlines to allow the same time (or close to) spent in each gear as before while still enjoying the benefits of the higher torque multiplication. Non-revup/HR Z's with stock redlines that go from 3.5 to 3.9 rear ends feel quicker in each gear because of the higher torque multiplication but are ultimately not much quicker (if it all) in the quarter mile because they have to shift more often as well. But again, I didn't say it's useless without a higher redline; I just said it's not being completely taken advantage of, especially cars that are making significantly more power than stock.
My alty SE-R tranny will be going along with a 7200-7500 redline depending on what my "Stage 1" powerband dictates. We'll see...
This is very interesting indeed. I was considering doing this, but wasn't sure exactly how to achieve the best benefits from this swap. Thanks for the 101, nismology. My other question would be, what tranny's and from what years would work with the 3.5 better then what the 5.5 comes with, while still maintaining the HSLD and also proven to have better synchros? I have a horrible crunch in my 3rd gear as well.
This site has tech information on all Nissans going back pretty far. You can compare the options, gear ratios etc.... http://www.nissanhelp.com/Models/
My car feels faster and and runs lower 1/4 mile times with the 6th gen gearbox. I'm sure part of that is the HLSD. I still roll through the traps in 4th so it's not an issue in the 1/4 mile. A higher rev limiter would be nice but our cars have a nice wide power band already and the final drive is still not very low.
One thing I've noticed when racing other cars (legaly) is they all shift more even when I'm wining.
soooo heres my latest option:
6th gen hlsd tranny with 10k miles WITH new fidanza flywheel and spec stage 3 clutch for $900 + my old tranny....sounds pretty good right?
woohoo its a go then...this will take place next saturday. I hope I like the end result, especially with the performance parts. Im not much of a racer though I love getting on it from time to time...what can I expect from these extras?
The Fidanza flywheel is really nice. It makes a noticeable difference.
I had a Clutchmasters stage 3 and the pedal was way too stiff. Not comfortable for a daily driver. It was pretty bad a$$ being able to bark the tires going into 4th though. I took it out while it was still good and replaced it with a 350Z clutch which I really like.
I've never used the SPEC so hopefully it wont be as stiff as the CM. I'm sure others here can weigh in on the SPEC.
Either way it sounds like a good deal to get the $500 flywheel in the deal.
I have the Fidanza and SPEC Stage 2 installed. It's been about a month and a half now with it in and I'm still loving every minute of it. I will tell you that there will be mucho chatter with your Stage 3. I had a Stage 3 in my Legend Coupe 6-speed and maybe it was the car but it wasn't nearly as much chatter as my Stage 2 in the Maxima. Either way, once it's in gear then it's not gonna budge. The Fidanza is just amazing, my 1st lightweight and the rewards from it is worth every penny to me. Good luck with your install!
btw......how and where did you get such a great deal from on the tranny? I want in on the secret.
thanks man...is this chatter will going INTO gear? I wanted to get AWAY from the grinding lol
your maxima will rev up like a bike. I have the 06 tranny, fidanza flywheel and exedy stage 1 clutch. When you mat it in first gear you better not blink because you will be shifting into second gear with your eyes closed. The synchros are far smoother than the 03. The new final drive will accelerate like an sti in first gear. There is definitely more torque. IMHO this is a much better setup than the 03 stock. But, because you rev a little higher you will lose a tiny bit of gas mileage. It also helps reduce the drone from headers because it gets you out of the 2200 rpm zone on the highway.
I get a little chatter on the downshifts, and a bit when it goes in reverse.
It's just chatter, no grinding. I have chatter when I release the clutch in almost any gear other than 5th and 6th. More-so when downshifting, or granny shifting. Usually when upshifting you're pretty much on the accelerator anyway so it revs out the chatter. I don't have an issue with it, some others do.
The dream is very much alive though.
yea man I hear you on that...I hate local riding - so many people run stop signs, back outta driveways etc etc. I try to get on the highway whenever I can, not because I could open it up, but because in my opinion its actually safer. You shouldnt let that stop you from getting one though.
And thanks to everyone who helped me out. The swap will take place next saturday. How long of a job is it btw?
now I have an o/t question about the grinding...
it seems the only time I want to "test" the grind is when the car is parked but on, I rev to 4500 and put it in 3rd, it will grind like crazyyy. But when I'm pushing 2nd gear hard into 3rd, nothing, zip, nada...I just want to know why? As a matter of fact, I'll make a soundclip for you guys right now. Give me a few
edit: got it, just gonna take a few min to upload it
So your 3rd gear is not toast. If you just wanted an excuse to replace the tranny, fine. But nothing that would warrant replacement on its own is wrong with the tranny from what you've told us.
If I wanted an excuse to replace the tranny I would have done it 20k miles ago when I first started noticing it. Since then it became worse and yes 3rd gear grinds hard sometimes when I'm driving and it may or may not get worse. It's not a risk I'm willing to take. Thats why Im looking into getting a replacement tranny, specifically, the one I mentioned in post 14.
ok...Im going thru with that tranny I mentioned in post 14 and its being installed in 3 hours in a shop after hours....:::crosses fingers::: for a clean swap. I'll post up my review later
Old tranny:
Flywheel on:
and thats it! Im happy for a successful install. Car revs up sooo much faster now. I stalled out a few times getting used to the new clutch feel. 3rd gear is great now too! woot!
