HELP - All front lights except heads are off
Old Nov 11, 2001 | 05:27 PM
klubjunkee's Avatar
To start, I have a 96 GLE. I have all my lamps rewired. Brighter clearance mod, stock side markers and aftermarket sidemarkers to echo with signal, and signal switched to dual socket 1157 to remain on.
I've been fine with this setup for the longest time. I have no clue what happened but I just noticed today that none of my front lamps remain on when headlights are on yet they still blink when signal or hazard. The funny thing is my clearance now only comes on when I signal. As well, they don't alternate or echo when signal - instead they all blink together (Signals, Sidemarker, aftermarket sidemarkers) I've check all the fuse just in case and it's all fine. So what the heck could be wrong? Any help would be appreciated. Thanks in advance.
The picture below is how it was, all remained on and sidemarkers echoed with signals and now all that's on is the headlights.
Old Nov 11, 2001 | 05:39 PM
ericdwong's Avatar
Re: HELP - All front lights except heads are off
Are you sure you check the "tail" fuse? which is 7.5 amp? The tails are wired into the fronts so your tails are probably out too. Check this thread... http://forums.maxima.org/showthread....ghlight=lights
Old Nov 11, 2001 | 05:58 PM
klubjunkee's Avatar
Re: Re: HELP - All front lights except heads are off
No, tails are fine and I check that fuse too in case. I have no clue what it could be, I even rechecked all the wiring and nothing seems to be loose. It's just wierd that they signal but none stay on. The clearance and sidemarker as stock stays on but now it just comes on when I signal. This is just bumming me out.
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
Samedi
Aug 12, 2015 01:54 AM
papo99
Aug 9, 2015 07:32 AM
