Need Help, New Battery Car wont do anything
I need help. Last night after coming home, I made a mistake and left my keys in the ignition. Car was off but switch was in the ON position. This morning I discovered that the keys were still in car. Tried to crank car and nothing. No lights, no horn no anything. Went to get a new battery and car still does nothing. The horn does not blow, the lights do not come on, and car still will not start. Any ideas as to what the problem may be? Any suggestions as to what I should check? I have a 2002 SE
you could have probably just gotten a jump start...
only things i can think of are you installed the battery backwards or your terminals are not making solid contact.
pray that its not the first one, i had a friend that did this and it blew his main fuse but before it did that it shorted out a few wires under the dash which he conveniently called me to fix...
What he meant was instead of buying a new battery you could have jump started the old one to get the car going. The alternator would have charged the battery back up if the old battery was still in good condition.
You really shouldn't have blown a fuse unless you did install the battery backwards. Check the battery install first, then the fuses.
after checking the fuses, it does look like the main 120a fuse on the positive battery post may be blown. Does this fuse just pull out or do I need to loosen anything? I tried pulling on it and it did not budge. I noticed 2 screw near it. Just wondering if these need to be removed.
problem has been resolved. It was the 120V fusible link on the positive battery terminal.
I replaced it and the car cranked right up.
FYI I know how to jumpstart a car. I was confused as to how it was written. Thanks for all the info though.
Leaving the keys in the ignition did not cause it to blow. I have a habit of disconnecting my amp before I attempt to boost (jump start) my car or give some one else a boost. Evidently when I was doing this something must have touched because after I replaced main fuse, I noticed that the amp fuse was blown also. All have been replaced and all is good now.
I'd start a new thread for this but I'm too new and am not allowed.
I was helping someone with a jump and when I went to start my car there was sparking. Checked all the connections and everything was connected properly, so we just pulled everything off and tried again. Then when I went to start my car (the good battery) it just clicked.
Now two cars won't start. We got another car to start the other but now my Maxima is dead in the water.
All electronics (radio, headlights, interior lights, etc) function.
I took the battery out and took it to Advance for a test. Tested out fine.
Reinstalled it, making sure connections are good. Still nothing. I get a few clicks out of her, then it stops completely until I turn completely to off position and try again.
Any ideas?
228k + miles on it. It's a 2001. The air bag light has been blinking and I have a CHECK ENGINE LIGHT which is what I was going to get looked at when all of this happened.
Any ideas?
What is your battery voltage? It should be 12 volts.
When the sparks happened, were they tiny sparks or big bright sparks? Tiny ones are normal most of the time.
Have you taken the battery cables off of your battery and cleaned them since this happened?
Type of sparks - that's kind of subjective
but let's go with tiny sparks.I have not taken the battery cables off and cleaned them.
sounds like you blew the alternator fuse/main fuse. As mentioned it's the large oneright on the terminal. Also, clean the connections,and havea friend wiggle the terminals while trying to start
Does anyone know how to get it out of there? I'm worried I'm going to damage something further.
I went to Auto Zone to get this fuse and they told me I had to go to the dealer. That was my next stop. They didn't have any in stock but told me they could get it for me next day for $45. I know I've read about this in other threads and people have mentioned 1) that it should be available at a retail store like Auto Zone and 2) that the part cost around $10.
Does anyone have any experience with this to confirm what I'm experiencing?
In the meantime, I found what I believe to be the correct part on the AZ website for $3.29, no shipping charges included.
Here is the link: http://www.autozone.com/autozone/par...152125_0_45952
I was able to purchase the fusible link at another Auto Zone in town. Only $3.29. Unfortunately, that didn't do the trick.
I'm getting it towed to the shop this morning. Don't have the time, tools, or expertise to mess around with it any longer.
Thanks to all who've replied to my posts!
Just to keep those that are interested up to date.....My mechanic said that it needed new cables. He is replacing those and the radiator (obviously unrelated to my starting problem). I should have it back tomorrow. I'm hoping this addresses the issues I've been experiencing. I was hoping to get another 70k out of her to reach 300k miles!
I'm sure this is a question with many answers but.....when do transmissions typically fail in the 5th generation maximas?
).See post #10 above; I don't remember the exact steps involved, but you have to practically disassemble the whole terminal.
Lakersallday24
Jun 16, 2019 01:35 AM
doobadoo
Aug 15, 2015 06:43 PM
Superbform
Aug 11, 2015 08:10 PM
