Fidanza vs. Stillen Flywheel ... What other parts are needed?
Hey everyone, I am doing a 5spd swap soon. I just ordered a ACT heavy duty pressure plate and performance disc with the stillen flywheel. Now I think I made a stupid move ... Since I do not have a flywheel currently, what additional parts are needed to make the stillen flywheel work? I read that the fidanza is preferred over stillen because it it slightly heavier. Does fidanza require the same amount of OEM parts to be reused just like the stillen flywheel?
I can probably cancel the order first thing tomorrow morning and go with the fidanza wheel instead ...
Any advice?
Any advice?
What about the ring gear? Isn't that used for the starter? What is the timing gear for, crank sensor?
I'm not sure which is preferred I'd research their weight and see if anyone made any comparison threads about the two.
I had a fidanza and I loved it. If they are both the same weight and balanced properly I cant really see what the difference would be besides price.
Does the ring gear have to go on a certain way in order to maintain balancing of the entire flywheel assembly? Where can I find the torque specs for the ring gear as well as the flywheel to crank?
fsm has torque specs. does not need a specific orientation, put the ring on make sure all the bolts are in and tq them down and your good to go.
when I get to my portable hard drive I'll check the tq specs and posted them up if you cant find them
You're also going to need a set of pressure plate bolts and washers, since neither the clutch nor the flywheel usually come with them.
I happen to have a set for sale, see my sig
Its also showing the oppostie side that the Fidanza is showing...
Flava, did you own both stillen and fidanza? Which one is preferred, and why? What is the weight difference?
Also OP you asked about orientation, it can only be assembled one way because there are pins.
BTW I have the stillen and I like it.
Also DONT use an airgun like I did to take it apart....youll strip bolts. And also use loctite when putting back together otherwise bolts (that were torqued to spec) will come loose and youll be taking your tranny off a second time to replace the timing ring. Learn from my mistakes.
The Stillen weighed in at 7lbs naked, once the timing and starter ring gears were attached it was about 10lbs... maybe a tad bit more.
The Fidanza wieghed 12lbs complete so its just a little heavier.
In the future, if I did choose to keep running the lightened flywheel I would stay with the Fidanza. Just an easier setup to me.
Update guys ... I canceled the order on the Stillen flywheel and will be purchasing the fidanza on ebay for $310 shipped. Still cheaper than the stillen flywheel under their black friday special of $375.
I know this thread is a little old but it is the only one that I found that talks about stillen, findanza flywheels. So I have a 95 max that was manufactured on 11/94 so that means I can't use the findanza flywheel it's only for 2/95-99 so that leaves stillen and unorthodox but on unorthodox's website it does not show one for a 95 max but other sites do like horsepowerfreaks or is their a certain month of manufacture that it fits in 94/95 does any one know? And stillen actuley has one on their website but dose it come with a starter ring gear or a timming gear ? And can you re-use all the parts from the old flywheel (ie starter ring,timming ring,bolts) or do I have to buy new ones and were can you find them? does the the stillen come with the center section?
Any information is greatly appreciated.
http://forums.maxima.org/4th-generat...it-1995-a.html
Dose anyone know if the 95-01 stillen flywheel bolts to a 95' max ring gear without having to drill a new hole into the ring gear. Like the problem with findanza flywheels on an early production 95' maxima.
FWIW the ring gear isn't the apparent problem for the early '95s, it's the timing ring. Two entirely different things.
Sorry I was mistaken, I thought I read Drill the ring gear to fit the findanza flywheel in the findanzas don't fit 1995 thread, but in fact it's the timing ring
. So confusing when you can't see what were talking about, But you wrote that the stillen works in the early prodution 95' so I will buy that flywheel. And what is the automatic flexplate
.From the pictures posted above, that's apparently how the Stillen flywheel is set up, as I don't believe you can separate the center piece from the OEM flywheel.
Again, this is just from looking at the pictures; have no experience with the Stillen flywheel myself.
The flexplate is essentially the flywheel of an automatic.
Thanks for your help, I think that I figured it out correct me if I'm wrong. Had to have lunch for the brain to get around it. The reason is the findanza only comes with the flywheel and starter ring and you have to reuse you stock timing gear but on early 95' one of the bolts don't line up so the timing gear gets anew hole drilled, no thank you to that idea want a bolt in application. But on the stillen you have to use both the starter ring and timing ring as stillen dosn't supply these with their flywheels so with that said is it safe to say that the timing ring is bolted to the starter ring gear and then the starter ring gear is bolted in the same pattern as the rest of the 4thGens to the flywheel and thats why the stillen will work on an early production 95' without having to drill the timing ring.
kenc15
Sep 25, 2015 06:38 AM
Team STILLEN
Aug 10, 2015 04:29 PM
