Pulsey steering when cold
Old Dec 17, 2008 | 09:33 AM
Bassbreaker's Avatar
OK, I have a 1995 GLE with 263K (kms)
It seems that when the car is cold, and i'm shifting into drive and ride the brake and even when accelerating a little, the power steering seems to cut in and out ie: become pulsey for only a min. Then after a min it goes away.
I know i need a new idler pully cause the bearings are shot and it squeels upon start up but also goes away after a min. Since this is part of the altinator, pulleys, blah blah...could it have to do with that?
I'm afraid that i might loose my power steering on the drive home (30kms) or have to replace something really expensive.
Where is the PS pump and belt located to? Is it joined onto the whole pulley system that the altinator is attacted to?
Thanks in advance
Sean
Old Dec 17, 2008 | 10:40 AM
IlyaK's Avatar
The Golden One
You mean it's hard to turn the wheel when you first start the car?
That's normal if it's super super cold out. That's why I let my car idle for at least a minute on really cold days (10 degrees for example).
Old Dec 17, 2008 | 10:54 AM
i'm not talking super cold out...like -2 to -5 degrees celcius. It's like the PS cuts in and out rapidly
Old Dec 17, 2008 | 11:01 AM
IlyaK's Avatar
The Golden One
I still think you're experiencing the same thing I just mention. It's just cold...give it some time.
Old Dec 17, 2008 | 11:05 AM
ok...will do. Thanks
Old Dec 17, 2008 | 11:25 AM
IlyaK's Avatar
The Golden One
Is it hard to turn the wheel when you're backing out of, say, a driveway or parking spot? And then the problem goes away?
Old Dec 17, 2008 | 11:32 AM
sort of yea...backing up and going foward, it's the same. But it on;y occurs for about 45 secs or so then when all the whining of the pully settles down it stops....
Old Dec 17, 2008 | 11:58 AM
IlyaK's Avatar
The Golden One
Definitely just cold man.
Old Dec 17, 2008 | 12:02 PM
yo must be right, cause when the engine bay is nice and warm it never happends
Old Dec 18, 2008 | 11:40 AM
njmaxseltd's Avatar
Replace the belt, it may be glazed which is why it's slipping when it's cold.
Old Dec 18, 2008 | 12:13 PM
which belt is it tho...i'm not sure where the PS pump is to look at the belt. Is it under the PS fluid resivoir?
Old Dec 19, 2008 | 11:00 AM
MikeDnepr98's Avatar
Here is the picture of where the pump is located. It’s most definitely the belt. Before replacing the belt check to see if it is in good condition. Maybe all you need to do is to tension it. Also make sure you have enough power steering fluid.
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
