Parking Lights and Fogs only
Anyone know how to reprogram the system to allow only the parking lights and the fogs to be on? Another manufactures allow it, but Nissan vehicles only allow the fogs on when the headlights are on. I look the look of the fogs on without the headlights while dusk.
I think this sucks as well, I used to roll with just my fogs on my truck before the MAX, and I thought that it was just a feature most vehicles had......I guess I was wrong when I got my MAX, I am sure someone will find a way here eventually!
I made this change on both my 2nd gens, but there are a LOT more wires under the hood of these '09s, and everything is covered with shields and baffles. Maybe we have an electronics whiz here somewhere?
I like the Reverse Mirror Tilt (both mirrors)
Question, ive already changed my headlights to 6000k HID's, what is the bulb size to the fogs? the same as headlights "H11"? And also do i need a HID conversion kit as well like the headlights for the fogs or can i just go with the bulbs by themselves?
thanks!
thanks!
I was hyped about this until I checked the compatibility. It says 2004 - 2007 Maximas only.
Fog bulbs are H11. As for the HID kit, that all depends what you are looking for. If you want them to match, yes, get another HID kit. Just remember that they won't match from every angle because of the projector lens in the headlight. If you want to put in yellow fogs or something (like I did - much cheaper) then no, you can just get standard halogen bulbs.
It's only been tested to work on the '04 to '07, it may work on older and newer Maximas as well.
It isn't as simply as hooking it up to differnet wires, though. The module connects to a communication bus going to the BCM - some BCMs are compatible, some are not. There really isn't a way to tell until you try it out though.
In the newer Nissans it is much harder to just wire the fogs to the parking lights as the fog light relay is CAN bus controlled and integrated in to the IPDM. You can do it by adding a waterproof external relay (most are not, so make sure if it is going under your hood it is waterproof) but at that point you might as well just install the KPtech unit and have total control of the lights.
fog lights
I just gave up my Z on a lease, and traded my Titan in on a new Maxima. I had my fogs come on with my parkers in my Titan. I took a small 4 inch piece of 14 gauge wire and soldered a flat wire connector to each side. Then I connected them between the parking lights and fog lights. I did have to put a blown fuse in the fog slot to make it work. If you go to www.titantalk.com and search fog light mod.....you might be able to do this to the max, if you know which wires to jump.
its really simple, just get a flat head screwdriver to remove clips. You have to remove most of the clips in the front and I also removed some in the back. My hands are small so I slipped them up and removed the old fogs and put new H11's in. total time 10mins. to put the clips back in are easy. let me know if you have any questions
G
G
one of my boys had his 7thgen maxima done in long island where they added a switch to turn on and off the fog lights .....gotta get the name of the place as soon as i do ill let you guys know
I just installed my Nokya H11 hyper yellow fog light bulbs (2500K). It was very easy taking about 5 min per side. I just had to remove about 10-12 plastic pins holding the under-carridge. I then reached up and twisted the bulb about 45 degees, pulling out and disconnecting from the wiring harness and repeat in opposite order with the new bulbs. The only problem is I think the yellow dulls out the blue of the HID headlights. I am going to order the 7000K artic white Nokya and try those. I will let you know what they look like after I install them....
Thanks, it seems like adding a switch is the easiest way to go. I have a blank area where a switch could be installed. It would be great if all you had to do was to run a switched hot wire to the fuse block.
Some questions to see if I want to take on this job...
- Is the car pre wired for the fog lights?
- do you install a speterate switch for the lights?
- where would this switch go?
- or do you somehow add the switch to the stock switch?
I don't mind having a on / off switch so I can turn the on durning the day but want to make sure they go off when the cars off...
any help on this would be great as I hope to find someone who has done this already...
i have the 09S and i am goin to be installing a projector foglight HID light and the foglight will come on when my parklight is on. you dont need a seperate switch but they will need to convert either the voltage or currrent i think so the HID wont overpower the parklight.. i will keep ya posted after i get it done.. ps: just to convert it, it take 2hrs alone...
it was a hard and time consuming job. it took just 2hrs to make one side of the fog light come on with the park light because of how the car was wired/programed. it took that long because i had HID on the fog light and i had to put a relay and upgrade the wire of the park light. over-raw, it was a successfully job and my park light comes on without me starting my car. the fog light color is not green. it just look green on camera. i have 10k (skyline blue) for my headlight and 8k(skyline blue) for my fog light. my park light/front turn signal, reverse light/ rear turn signal bulbs are skyline white
I am sure it can be done. I actually did it when I had my 5.5 gen and never had a problem with inspection. Mine was wired to come on with the parking lights and turn off whenever you turned the high beams on. This makes it legal just like some other brands do it. Now that I have a 6th gen I have no plans to do such a mod because of the set up of the fog light in the hedlight assembly and not lower in the bumper like the 6.5 or the 7th gens.
