01VI Kit
01VI Kit
Includes Upper Intake manifold with EGR block off, Lower intake manifold, Fuel rail with Injectors, Rear valve cover, rear coil packs, and Throttle body. The only thing you'll need is the idle air control valve or to block it off. you can Use your TPS, and you dont even need a fuel rail adaptor.
$375 shipped for pretty much everything needed to make this bolt on.
well, its a variable intake manifold, at a certain rpm the stock manifold falls flat on its face. With this manifold, there are butterfly valves that open up at a certain rpm. your power will continue to increase after that rpm. Approximately a 30whp gain in some spots probably. It actually gains power throughout the low rpm range as well. It also includes larger injectors.
yes i still have it!!
since i have every component from the 2001, everything will bolt right up without modification. the lower intake manifold will bolt right up to the stock engine, the fuel rail will bolt up to that, the upper will bolt up to that. This kit has an egr block off, so you can either block off your egr, or if you want egr you will have to get a 5th gen egr pipe. Like i said before the only thing you will need is an idle air control valve, or to block it off. Some people dont even run an idle air control valve. Let me know man, pm me.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
