FS: 01VI kit
FS: 01VI kit
Comes with Upper manifold, lower, throttle body, EGR block off, Fuel rail, injectors, injector clips, rear valve cover, rear coil packs....almost everything except for the iacv.
$280 shipped, Trades are VERY welcome...make offers!!
interested!
has everything been modified to be completely ready to go? just add an IACV and i'm pretty much set? the only thing keeping me from getting an 00vi is the drilling and modding.
there is no drilling or modding required!! well, the only modding is to splice the injector harnesses into your harness....two wires each injector! Thats it. Since youre using every component from the DEK, it is a direct bolt on.
I have done some searching but no one really seems to give like a wikipedia detailed explanation. Or I just don't understand, why do I need a new IACV what kind do I need, and if the egr is blocked off at the intake would I need to do something to keep the exhaust from leaking into the engine bay? But yes I am very interested I have been looking into a MEVI because I was afraid of all the extra work but you kind of sold me on it saying that 00vi is easy, or at least this one.
If you search, and read, you'll find the answers to all of your questions.
The A32 IACV does not bolt up to the A33 UIM, that's rather obvious. Hence, you need to use either the A33 IACV or get an adapter plate to use the A32 IACV.
Not if you disable the EGR valve. You can just get the EGR block off plug from Nissan, to replace the EGR tube going to the rear exhaust manifold.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
