WTB: VG rod and piston
Old Jun 5, 2009 | 10:20 PM
benz-tech's Avatar
I need to send a piston to BRC for some measurements. I could return it if needed.
I also need a good connecting rod or 2 - must say "w" on it.
Old Jun 12, 2009 | 09:38 PM
Chris Gregg's Avatar
Get Off My Lawn
You don't indicate what your project is and I couldn't identify what gen your working on. The "w" is the modified block, right? Has the long snout as opposed to the short snouted, single woodruff keyed "a" block from the earlier z's and max's?
Not sure if this helps, but I have an entire VG short block: Crank, pistons, rods, oil pump...assembled. My short block is the newer "w" block with the long crank snout. Where are you located? Interested in an entire short block? If not, what are you offering so I can determine if it is worth it to dissassemble my short block?
FYI: My short block came out of my Max, had close to 200k miles, ran strong with a little oil use and only slight smoking when cold. I have a brand new set of Nissan stock piston rings for a turbo, but should also be good for N/A use as well. With a good hone, these rings, and have the crank turned for good measure, this short block will be perfect for any modifications. Knowing how strong this engine run before, is exactly why I've kept it around. I've simply focused on my turbo which is in my Max now.
Let me know.
Old Jun 15, 2009 | 12:14 PM
BRDSURRATT's Avatar
I have got 5 of these that are good are you still needing one? rkearns@ptmc.net
Old Jun 16, 2009 | 04:41 PM
benz-tech's Avatar
got one. thanks for the replies.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
6spd4dsc
Mar 4, 2016 05:19 PM
knight_yyz
Nov 1, 2015 01:34 PM
londonflu
Sep 19, 2015 02:33 PM
