Spacer Question
Old Jun 6, 2009 | 09:48 AM
Professor's Avatar
Spacer Question
I picked up some nice 10 mm spacers, there machined aluminum , but i had several ppl tell me there is a high change of the studs snapping from the spacers, Is this a myth or something i need to think about ?
Old Jun 6, 2009 | 08:15 PM
z32drifter's Avatar
I don't know why spacers would cause the studs to fail. You do need to replace your stock studs with longer ones.
Old Jun 6, 2009 | 08:24 PM
Um that makes no sense man.
Old Jun 6, 2009 | 08:28 PM
Puppetmaster's Avatar
If you doubt the quality of the extended studs that come with the spacers, look into some ARP extended studs.
Old Jun 7, 2009 | 06:44 AM
Professor's Avatar
The spacers themselves did not come with extended studs, i realized that i needed longer ones once i tried to put them on, i had a brain fart, can you direct me in the right directed to get the correct arp studs for the rear.
Old Jun 8, 2009 | 10:21 AM
MrDicks95SE's Avatar
Offset Is Everything.
see if you can get H&R studs from AuToMaX_95 in the GD section. ARP works as well.
nissan thread pitch: 12x1.25
Old Jun 8, 2009 | 02:35 PM
Professor's Avatar
ok thanx, ill check into them.
Unclejunebug
Apr 2, 2016 05:42 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Socalstillen
Sep 26, 2015 12:01 PM
