F/s 03 Headlights & Umnitza DDE's - READ DESCRIPTION!
READ DESCRIPTION CAREFULLY:
Up for sale are drivers and passengers side headlights off of a 2003 maxima. These headlights have the stock Xenon bulbs along with the ballasts. The amber turn signal lense has been cleared out and replaced with the clear lense. They do NOT have the highbeam/turn signal/parking light bulbs.
These headlights had the Umnitza DDE set up, but unfortunatly the DDE's got the "pink eye" problem so I just disconnected the halos from the ballast since I had no time to replace them.
I also have the replacement DDE's that I didn't get around to installing.
Then a few weeks ago I got hit in a parking lot and got a slight scratch/scrape on the driver's headlight plastic lense. Hence I'm selling this set.
This set is good for a project set if you want to install DDE's and black out the housing.
So just for clarifaction here is what is in this set:
>Drivers Side headlight with the stock Xenon and ballast. has a slight scratch on the lense. Has 2 bad Umnitza DDE rings, and a good ballast for the DDE kit
>Passenger Side headlight with stock Xenon and ballast. Has 2 bad Umnitza DDE rings, and a good ballast for the DDE kit
>Replacement DDE rings (4 total)
>Wiring for DDE kit
I'm trying to sell these as a complete set, but willing to take offers for part outs. I'm asking $240 OBO for the whole set. Or $220 for both headlights and $55 for the replacement DDE's
PICTURES COMING LATER TONIGHT.
>Wiring for DDE kit
Here are the pictures...
Passenger Side (the tape holds the DDE ballast to the stock ballast for a neater install):
Passenger Side Back:
Drivers Side Dent/Scratch (it is not punctured through at all, just surface scrape):
Drivers Side Dent/Scratch again (The accident caused the lense to come off from the housing a little bit, hence all the gray sealant looking like crap but it is no problem since you'd have to bake the headlights anyways to take them apart to install DDE's)
Drivers Side Rear:
Drivers Side Rear:
The whole kit:
DDEs:
DDEs:
and here is how everything looked before the pink eye problem and how it will look again when you replace the DDE's
DDEs:
DDEs:
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
sdotcarter
Sep 2, 2015 09:53 PM
