how to know if mirror is heated or non heated?
Old Aug 16, 2009 | 09:50 AM
albo's Avatar
Just like the title of the thread says, searched the forum but was unable to find anything. my right passenger mirror got shattered, and when I’m looking into purchasing an new one I run into the options of heated and non heated, is there an easy way to find out what mine was?
Thanks before hand.
PS: If anyone has an right evergreen colored one with an good price pm me.
Old Aug 16, 2009 | 09:54 AM
allensteiner21's Avatar
dude...turn on the rear window defrost and check if the mirror gets warm.
Old Aug 17, 2009 | 09:39 AM
Also, if you have heated seats, it means you have the cold weather package which includes heated mirrors.
Old Aug 17, 2009 | 04:38 PM
maxfever1987's Avatar
fold your mirrors, if you see and H with any combination of number that means its heated
if you have factory heated seats that means you have heated side view mirrors
if you take off your door panels and see if you mirror has 2 plugs to it you have heated side view mirrors/
Hope this helped
Old Aug 17, 2009 | 04:39 PM
not quite, i have a 96 gxe base model, but i did an upgrade and now i have heated seats and side view mirrors.so by turning on the rear defrost doesnt prove it
Old Aug 17, 2009 | 05:57 PM
JNCoRacer's Avatar
Just the tip.
I have heated seats, no heated mirrors. But then I have an I30 so those may be different.
Old Aug 18, 2009 | 03:42 AM
pmohr's Avatar
No more Maximas...
Well if one were to have done this upgrade, does it not stand to reason that they wouldn't be asking on the org whether or not they had heated mirrors?
Old Jan 3, 2013 | 10:30 AM
temblor's Avatar
Same question How do you ID A heated mirror?
I am looking to buy a used one. How do I identify whether it is heated or not? At the wrecking yard or if I buy off ebay?
A lot of sellers are not sure..
Old Jan 4, 2013 | 06:00 AM
Trini Boom's Avatar
Hope this helped
^^This..
Old Jan 4, 2013 | 06:21 AM
dwapenyi's Avatar
My I30t has heated seats and mirrors. Maybe its an I30t thing?
Or maybe its regional, mine being a 98 california car
Old Jan 4, 2013 | 06:36 AM
JNCoRacer's Avatar
Just the tip.
Nope, I was wrong. I do have heated mirrors. I always park in the garage so I never had frost on them to tell.
Old Jan 4, 2013 | 08:54 AM
benjie's Avatar
So just to verify. If you don't have heated mirrors, the wires are already in the door so all you have to do is buy heated mirrors and plug them in?
Old Dec 23, 2014 | 11:07 PM
adnanvq's Avatar
my 99 currently has non-heated mirrors, i bought some heated ones on classifieds. Are they plug and play??? i hope so
Old Dec 24, 2014 | 05:11 PM
No not plug and play
Old Dec 24, 2014 | 05:53 PM
You will need to tap into a power source and ground, you need to be able to turn it on and off, best way is to wire it up to your rear defrost
Old Dec 24, 2014 | 07:58 PM
ac max 92's Avatar
Another way to be certain is to pop the glass off the housing it just pries off but be careful not to break the clips when prying it off and you will see a white heating pad on the back of the glass. If they're not heated you could probably mod it if your handy. Most 3rd gens have heated glass.
Old Dec 28, 2014 | 03:13 PM
carsnwomen91's Avatar
they only turn on with rear defrost? i thought they were always turned on when the car turns on hmm... my suggestion to check would be to throw some snow on it and see if it melts faster than on the plastic part of the mirror body? lol
Old Dec 28, 2014 | 03:52 PM
That wouldn't make any sense...
Old Jan 7, 2015 | 11:06 PM
i know but once i turned the car on in the winter it would start melting away, i guess i also had the rear defrost on so i must've never noticed.
Old Jan 8, 2015 | 07:26 PM
adnanvq's Avatar
Damn, i thought that the wiring harness connects the same way as the current mirror, does the heated mirror have two connectors? and doesnt my car have the thing to plug it into?
Old Feb 21, 2019 | 05:45 PM
agustincorrea's Avatar
Can I add Heated Mirrors from another Maxima to my Maxima which does not come with them? Is the car already wired for Power Heated mirror ?
Old Feb 21, 2019 | 06:29 PM
JvG's Avatar
JvG
I really don't know the answer.
In general, the car companies find it is less expensive to have one main wiring harness for a car than separate ones for base, standard and luxury models rather than separate ones. There might be a sub harness between the main harness and the item you might want to install. So you might want to do research regarding the intermediate portions of the harness. That portion should be available at the local wrecking yard for little money.
Old Feb 22, 2019 | 03:54 AM
allmazda's Avatar
I added heated mirrors a few years ago. The body side of the door harness has the wiring. You need to get a door harness with heated mirrors- just the heated mirror wires and de-pin just the heated mirror connector from the main door harness plug. Remember there location and re-pin them back into your old harness. Next you need to pull the heated mirror relay. The connector is there you just need the relay and mounting bracket.
Not sure what it is called but the body color painted part of the mirror is removable. If you are lucky and these look good on your car you can hunt for any color heated mirror and swap the painted section.
Old Feb 22, 2019 | 07:19 PM
krismax's Avatar
Father of the 00 VI
I'm confused ,there not a button like others cars on the mirror switch,to turn it on and off. So my 01 has heated mirrors? It has heated seats leaded SE, Manual.
Old Feb 26, 2019 | 01:18 PM
DizzyEdge's Avatar
What does that mean?
The rear window and mirror defrosters for 4th gens are all controlled by the defroster button.
dejahn23
Aug 14, 2007 11:11 AM
tsk808
Jan 11, 2007 03:07 PM
nguyendot
Apr 26, 2005 05:15 PM
Zack342
Feb 25, 2005 04:08 PM
Mosphet
Oct 17, 2004 09:12 AM
