Hoses on passenger side of trunk inside body??
Old Aug 31, 2009 | 05:10 PM
SSzretter's Avatar
So I noticed my rear passenger side body panel is rusting out, and also noticed a couple rubber hoses hanging where there used to be metal. I think one or both of them where connected with some kind of flange to the metal that is now gone.
If you open the trunk, inside to the right (passenger side) is a compartment that I believe is supposed to hold the jack. You cant see the hoses there, but that is where they are basically...
So if you go under the car and look at the bottom of that compartment, which on my car is totally rusted out so I can see up in the compartment, there are two hoses.... They go up, but not in to the trunk as far as I can tell...
I just need to figure out what they are and what I should do with them...
I posted a different message about what to do about a replacement panel...
Old Aug 31, 2009 | 05:32 PM
pmohr's Avatar
No more Maximas...
One is for the antenna, the other is a drain for something else.
I mention them in my antenna replacement video.
What do you mean 'what you should do' with them? Hook them back up properly.
Old Sep 1, 2009 | 10:48 AM
ampire's Avatar
probably the drains and probably the reason it is rusting if they aren't draining properly.
Old Sep 4, 2009 | 06:42 AM
91parkave's Avatar
the other drain is for the sunroof
03VQMAX
Dec 7, 2015 04:59 PM
iflexsteel
Sep 15, 2015 03:37 AM
lux97Max
Sep 14, 2015 03:54 PM
rtirbany
Sep 8, 2015 11:46 AM
jchronis2552
Aug 13, 2015 07:48 AM
