Rim offset and backspace question.. Please help me
Old Sep 9, 2009 | 08:43 PM
ricerocket336's Avatar
ok, im looking to purchase these wheels for my 03 maxima and the wheels im looking at have an offset of 48mm and a backspace of 6.71".. (i dont like the offset i want the wheels to be a little more flush with the fenders wells.) so i found the same wheels same bolt pattern, with a 38mm offset, and a backspace of 6.33''.
my qusetion is whats the "backspace" mean and do you think they will fit on my max? (the 38mm/6.33" backspace) with out any issues
Old Sep 9, 2009 | 08:55 PM
MorpheusZero's Avatar
Backspacing just means how far the wheel extends inwards from the hub. Less offset will push your wheels out to be more flush with the fender.
Old Sep 9, 2009 | 09:05 PM
Fast1one's Avatar
Just ignore backspace or offset. Use one or the other. Just a different way to measure/communicate wheel specifications.
Personally I'm used to just using wheel width and offset. Refer to the stickies in this section. Measure the amount of protrusion you need to be flush with your stock wheels and chose the appropriate wheel. You can find the stock wheel specs with a search.
Old Sep 9, 2009 | 09:13 PM
so do you think the 38mm offset wheels would look good on my 03 max?
Old Sep 9, 2009 | 09:18 PM
Fast1one's Avatar
If the wheel is 9.5 inches wide, yes.
Read the stickies...?
Old Sep 9, 2009 | 09:23 PM
they a 8.5'' wide
Old Sep 9, 2009 | 10:11 PM
Me too. The funny thing is that backspacing/frontspacing (or whatever they call it, I can't remember) is more immediately informative than offset and width, just nobody uses it.
Old Sep 9, 2009 | 10:50 PM
MrDicks95SE's Avatar
Offset Is Everything.
"Backspacing is the distance from the inside bolting surface (Hub mounting pad) of the rim to the outer edge of the inboard side of the rim. To determine backspacing simply lay the wheel face down and lay a straight edge (or board, or anything else that is flat) across the wheel. Use a tape measurer or ruler and measure the distance from the bottom of the straight edge to the hub mounting pad. This is your backspace and when choosing rims can help you determine rim depth in the wheel well."
i also agree that it is MUCH more informative rather than offset and wheel width.
Old Sep 10, 2009 | 05:55 PM
Fast1one's Avatar
Lol I know. For some reason its so much easier to compare rim to rim with offset
For example, if I have an 8 inch wheel that is perfectly flush and want to go wider, calculating the required offset just feels more intuitive. Must be habit
As far as for 8.5 inch wide wheel. It would be ok. I would shoot for something like +30 all around personally. Spacer in the rear to match or camber in fronts and go lower offset like +25. That's pretty conservative still.
I'm running 9 +24 all around in my 4th gen. But that requires stretched tires.
Old Sep 12, 2009 | 10:55 AM
but only slightly stretched. running 235s on my 9.0JJ et+25 with clearance all around. but those will soon be gone
Old Sep 12, 2009 | 10:16 PM
Fast1one's Avatar
Yeah, slightly stretched to OUR standards
Old Sep 13, 2009 | 08:38 AM
DAVE Sz's Avatar
Hooooooonda.....
hmm, so 17x8 +25mm would work fine on a 4th gen? wouldn't it stick out slightly?
Old Sep 13, 2009 | 05:40 PM
no it will stick 13mm in towards the car.
Old Sep 13, 2009 | 07:44 PM
Fast1one's Avatar
That size will be fine for most normal enthusiasts
Old Sep 14, 2009 | 09:49 AM
DAVE Sz's Avatar
Hooooooonda.....
as long as it doesn't stick out, I can live with 13mm...
SSRs here I come...
Old Sep 14, 2009 | 10:45 AM
Fast1one's Avatar
SSRs here I come...
If you have zero camber up front it will stick out roughly 5mm. -1 degree will be perfect flush. Rear will be sunk 10mm or so.
You will not notice 5mm though. Will look flush
Old Sep 14, 2009 | 12:19 PM
sunken rears FTL. throw a 15mm spacer in the rear.
Old Sep 14, 2009 | 01:28 PM
Fast1one's Avatar
Depends on the tire. I was thinking 10mm with rolled fenders.
Old Sep 14, 2009 | 02:46 PM
DAVE Sz's Avatar
Hooooooonda.....
-1.5 up front....
Old Sep 14, 2009 | 03:07 PM
Fast1one's Avatar
-1.5 up front....
8" +25 it is then
I would go wider, but at least you are going relatively flush. Keeping it fresh.
Old Sep 15, 2009 | 01:31 AM
15mm with rolled fenders. tire or not. do a fender pull if it still rubs. make it work. done deal.
Old Sep 15, 2009 | 01:32 AM
8" +25 it is then
werd. keep it flush.
Old Mar 10, 2010 | 12:44 PM
*2003MaxipadSE*'s Avatar
Hey I know im a little late on this thread here. BUT im looking to buy some rims for my 03 max SE. Im found some 18x9.5 wheels with 25mm offset in the rear ( 275-35/18 tires ) Will these rub???!!!! The fronts are 18x8.5 with 35mm offset and 245/40/18 tires. Its a good deal! help!
Old Mar 10, 2010 | 02:43 PM
IHAVEA2KMAXIMA's Avatar
I'm pretty sure they will rub... best bet is smaller tires (245s or less) and rolled fenders.
Old Mar 10, 2010 | 03:37 PM
ugh....that sucks. lol Thanks for the info
Old Mar 11, 2010 | 07:04 AM
Heres what im looking at, let me know what you think about fitment. ( mainly in the rear)
http://cgi.ebay.com/ebaymotors/18-AD...Q5fAccessories
Old Mar 11, 2010 | 09:20 AM
Fast1one's Avatar
I prefer that you go and measure to LEARN.
Give a man a fish...
Old Mar 11, 2010 | 12:00 PM
maybe i will then! Roll up them fenders a bit
Old Mar 11, 2010 | 12:14 PM
Wheels will fit fine. You can buy it and use the 245 in the rear and get some 225 in the front and sell the 275.
Old Mar 11, 2010 | 01:42 PM
J2FRESH's Avatar
i thought the rears had to have a higher offset to put a 9.5 on a 5th gen like 38-45
Old Mar 11, 2010 | 03:02 PM
Dont quote me tho, but something I've noticed is the 5th gen maxima can tolerate lower offset than say a 4th gen or i30/35 because we have the larger flares.
Old Mar 12, 2010 | 07:08 AM
Im still running stock suspension and it sure seems like the wheels are set in the wells pretty deep and I have about a 1.5-2" space between the top of my tire and my wheel well so im thinkin this is gonna work fine.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
0m3nc0w
Sep 11, 2015 05:21 PM
