ground wire points
Old Oct 13, 2009 | 09:47 PM
3000vr4tt's Avatar
ground wire points
so i was installing ground wires on a friends max......and so i tryed following the same ground points that i have on my 3000gt vr4......only wires i have left are 2..which on my 3000gt were alternator to the frame...and tranny bolt to the battery..can anyone help with pics or anything to find these bolts or where they are located? or any other points to use...thanks guys
Old Oct 13, 2009 | 11:40 PM
fastisnothing's Avatar
http://forums.maxima.org/5th-generat...grade-how.html
http://forums.maxima.org/audio-elect...other-how.html
Known as "The Big Three"
Any other questions, try using the "Search " drop down triangle at the top of the forum.
Good Luck.
Anthony.
Old Oct 14, 2009 | 11:48 PM
whiteSE's Avatar
another good one is where the starter bolts upt o the tranny
Old Oct 15, 2009 | 05:31 AM
JtzMax's Avatar
Whatchyou say?
I agree with the SEARCH ... this has been covered almost as many times as SeeFoam! * and NO, don't even ask what SeeFoam is ... how it works ... what it does ... or anything even close -
There's a Neg terminal on your battery, try that! You can use any place on the trans or the engine, find a spot and clean it well, strap your wire on and go.
Old Oct 16, 2009 | 01:40 PM
Sentientbydesig's Avatar
Pathetic grounding designs...
The negative battery terminal and factory grounding points are your friends. Add the transmission into the loop and you're done.
Old Oct 22, 2009 | 11:50 AM
3000vr4tt's Avatar
i know what seafoam is..im not a noob wit cars...just this search features kinda hard to find s*** sometimes
Old Oct 23, 2009 | 07:44 AM
JtzMax's Avatar
Whatchyou say?
LOL .... I hear ya man. Sometimes setting the 'priorities' at the bottom left can help. Also, hitting just the 4g forums is a plus too.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
