another f**kin MAP/Baro Thread :mad:
Old Oct 22, 2009 | 07:58 AM
MDeezy's Avatar
I've searched and seen several with this problem. Some fixed it some where not able to, from the look of the threads seems like either no one was able to fix it or did and never posted back.
Here in My Delima...
CEL on pulled codes: P110motherf**kin5 (yes it said that)
I am 3.5 swapped and have the sensor plugged in but no vaccum.
I ran this same setup on my 96 before and had zero codes, I can only assume this 97 ecu is a little more ****.
How can I fix this?
Ideal I have and will be trying/researching
-Resistor trick to fool the ecu?
-96 ecu and hope I throw no codes? (both cars fed spec MTs)
-macgyver up some vaccum to a/both ports on the sensor and lose the code?
Basically I need to pass emission (cant here in GA with the CEL on , its an instant fail) so even if I can get a way to get the f**kin code off for a few days just so I can test and it comes back on then cool.
I do have a vacc port on my 3.5 plenum that I could use..but just one...maybe a tee setup could be used ??
Old Oct 25, 2009 | 10:29 AM
deezo's Avatar
Are you using a MAP/Baro instead of the MAF?
Old Oct 25, 2009 | 10:34 AM
MDeezy's Avatar
nope. I still have the maf hooked up. map/baro sensor is pluggin in but I'm throwing a code for it.
they way I'm setup now I was setup on my my 96 and I was code free.
any idea?
Old Oct 25, 2009 | 11:01 AM
shadyonedeath's Avatar
the little green sensor?
im sure you have plenty of vacuum ports available. Does the 3.5 use vac for its fuel rail? T something off that.
Old Oct 25, 2009 | 11:03 AM
MDeezy's Avatar
little brown sensor.
3.5 manifold doesnt have much vacc lines but I have one I can use to tee off but does it need an in and out?
Old Oct 25, 2009 | 11:38 AM
MDeezy's Avatar
map sensor is like this (random pic i found)
if I run vac to the bottom source and that source be enough?
Old Oct 25, 2009 | 11:39 AM
bigleman's Avatar
Advocatus Diaboli
time for a new engine
MDeezy's Avatar
http://www.cyberhub.net/vi/Pictures%...%20of%20ME.htm
Old Oct 25, 2009 | 11:41 AM
MDeezy's Avatar
YOU need a new engine!
bigleman's Avatar
Advocatus Diaboli
somebody needs to teach that guy how the Macro feature works
Old Oct 25, 2009 | 11:42 AM
bigleman's Avatar
Advocatus Diaboli
i'll sell you mine
Old Oct 25, 2009 | 12:35 PM
urmab's Avatar
put 95-96 Ecu in your 97 will solve all your problems
Old Oct 25, 2009 | 02:02 PM
MDeezy's Avatar
Thats what I plan to do tonight. I have a spare 96 ecu. Going to toss it in tonight, and drive around tomorrow but i want to have a plan B incase it doesnt work for some reason...
Old Oct 25, 2009 | 02:44 PM
look at your FSM. Some ports need VAC and some need fresh air.
Old Oct 25, 2009 | 03:27 PM
MDeezy's Avatar
true...I'll look at it and check and see and test it out...
Old Nov 19, 2009 | 07:35 AM
deezo's Avatar
It's been a while since I've posted due to work and such but I'm sure you know that the 95/96 is going to throw some other codes even if it doesn't throw the MAP/Baro code.
Old Nov 19, 2009 | 09:17 AM
MDeezy's Avatar
surprisingly it didnt...it threw the exact same codes I was getting with the 97 ecu. I hooked vaccum up to it, and still same code, this start to make me wonder if the sensor itself is bad, because with the 96 ecu and the sensors plugged in, I never got a code for it.
I have an extra sensor I'm going to hook up today reset the cel and drive around.
Old Nov 19, 2009 | 04:27 PM
XeroX's Avatar
Hella internets
Maybe your just using a 95 96 cali spec? Im sure if you use a early 95 fed spec, it doesnt matter what you have as far as emisions...early fed spec 95's had barely anything...
Old Nov 19, 2009 | 05:37 PM
MDeezy's Avatar
nope its a 96 fed ecu.
going to swap my map/boro sensor for an extra one I have, that i know is good.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
AboveDaCloudz
Oct 8, 2015 11:25 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
