Car Having problems running in morning.
Old Nov 1, 2009 | 05:56 PM
TravisCadello's Avatar
Yes I have a Check Engine Light but haven't had it checked cause its OBD1 and cost to check it. Well anyways the guy sold it to me said when the motor is cold u have to rev it up untill its warm or it will just turn off. i noticed when it was hot outside it only sometimes idles at like 200 RPMS and then other times idles perfect most the times. pretty much when its warm outside it starts right up and idles low.
Well little bit ago i went to start it when it was cold beginning of today it took a while to start and then it turned right back off. i started it again and took a long time and then finnally turned on and smelt like pure gas. i held the gas pedle at a 1500 RPM Idle and it would strugle to hold that RPM. i would floor it for a second and it races up but at low rpms it just wants to die untill like 3 minutes of idleing it at 1500RPMs.
Its a 95 Maxima 3.0L. has new oil and new spark plugs and wires. just put fuel injector cleaner in BG last week.
Old Nov 1, 2009 | 06:39 PM
smai555's Avatar
check the stickies on how to get your CEL codes (really easy btw) and what they mean start there then reply
Old Nov 1, 2009 | 07:35 PM
aackshun's Avatar
Originally Posted by TravisCadello
Yes I have a Check Engine Light but haven't had it checked cause its OBD1.
Typo?
All 4th gen maximas are OBDII IIRC.
Old Nov 1, 2009 | 10:31 PM
Originally Posted by aackshun
Typo?
I thought only 96's and up were OBD2? So your saying my 95 Maxima is OBD2?
Old Nov 1, 2009 | 10:41 PM
aackshun's Avatar
http://forums.maxima.org/4th-generat...er-1995-a.html
Yup.
Old Nov 2, 2009 | 01:29 AM
flynlr's Avatar
if you spent more than 15 minutes reading the stickies you would know that.
Old Nov 2, 2009 | 01:49 PM
lbrowne's Avatar
When I had a very similar problem just recently, it was a combo of my FPR and then later my CPS (POS). (crankshaft position sensor, rear)
You can read the chain of events in this thread.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
acw
Aug 13, 2015 12:50 AM
